Topbiker49 Posted December 26, 2011 Report Share Posted December 26, 2011 Newb here looking for key blank. I just purchased a 94 Cutlass convert but it only has one ignition key. Does anyone know where I can get a key blank with the correct transponder chip? I have not been able to find a blank on ebay or anywhere else. If I have to go to a locksmith any idea of what it should cost. I have heard estimates all the way to $150.00. Thanks Quote Link to comment Share on other sites More sharing options...
bg35765 Posted December 26, 2011 Report Share Posted December 26, 2011 I got one off of ebay for about $10. You need use a multimeter and put it on the ohms setting to determine the resistance. Then look at the chart that you will find in the ebay listing that tells you which number key to request. Search ebay for "Cutlass Supreme VATS key". Quote Link to comment Share on other sites More sharing options...
Topbiker49 Posted December 27, 2011 Author Report Share Posted December 27, 2011 Thanks I got one off of ebay for about $10. You need use a multimeter and put it on the ohms setting to determine the resistance. Then look at the chart that you will find in the ebay listing that tells you which number key to request. Search ebay for "Cutlass Supreme VATS key". Quote Link to comment Share on other sites More sharing options...
