Psych0matt Posted December 22, 2011 Report Posted December 22, 2011 So I started up the GTP today (because why not?), and let her run for a bit to get all warm and cozy. I noticed when it was still warming up that there was a bit of smoke coming from beneath the valve cover, but not from the valve cover, but kinda seeping out between the front exhaust by the coolant line and AIR pipe that's right there, near the base of the cam casing. When cooler it seemed to be smoking a bit and would billow more if I revved it. Once it warmed up, it seemed to be a whole lot less. For example, the amount when revving warm was about the same amount when not revving cold. I did my oil drive O ring in the fall and I assume that to be decent (although I could be wrong), but this is coming from somewhere in the front. All intake gaskets are fresh, but I haven't done the valve cover gaskets (but it's not coming from the front side of the front valve cover at least). I'm not in a huge hurry to solve this, but just wondering what I may look at once I start digging, cuz I will want to fix this, and I think this may also be where I'm still leaking oil. Quote
Crazy K Posted December 22, 2011 Report Posted December 22, 2011 that's normal for an engine that has not run in a while... be more concerned if you had run it within a week and it was having the same issue.. Quote
Psych0matt Posted December 22, 2011 Author Report Posted December 22, 2011 Hmmm, alright. Yeah, I haven't started it in about a month. Maybe I just never realized it with anything else I've had I do know I'm still leaking a bit of oil, and i don't think it's from the O ring, but I can't really tell at this point Quote
brake Posted December 22, 2011 Report Posted December 22, 2011 I'd clean everything up as best I could and let it leak some more. Unfortunately the only way to find 'em sometimes. Quote
