oz37k Posted December 15, 2011 Report Posted December 15, 2011 Hello All, I finally found why I keep getting air in the system and the fans turning on late. I have a leak on the bottom on my radiator. Since I have a lifetime warranty I got a replacement and will be installing this weekend along with hoses, t-stat and new coolant. I also wanted to change out my ECT for my fans but it is on the plenum and I have done this before but I want to know if anyone has replaced the ECT without having to remove the plenum. I know there is couple of thing in the way, can they be moved out of the way or do I have to suck it up and remove the plenum? Thanks, OZ37K Quote
oz37k Posted December 16, 2011 Author Report Posted December 16, 2011 Noone? looks like I will have to remove top plenum then to replace my ECT... Quote
GOT2B GM Posted December 17, 2011 Report Posted December 17, 2011 i've never changed mine without having the plenum off, but it should become fairly apparent after a couple minutes of trying whether you'll have sufficient access with the plenum installed. Quote
