oil leak pics
I complained a few weeks ago about oil leaking from my car every once in a while. The biggest puddle of oil is about the size of a cookie. I got some pic to show you guys where I can usually see wet oil.
This picture was taken by the alternator if I reach down in that area my hands are covered in grease and fresh oil.
Could be the lower intake gasket..........and it could be a lot of other things, too. My first thought was lower intake gasket, maybe Timing cover though
Yeah, probably the lower intake gasket, pretty common problem. Could also just be the rear top pan, or also maybe the front cover and/or crank seal.
What should I do now, tilt the engine clean it up etc? I reached around the valve cover its clean no fresh oil. And I don't have fresh oil past the crank sensor. Just around the bottom there.
