Thermostat replace on a 94 3800 Regal
I want to swap tstat but have a couple of questions. I notice heat tube running over top of tsat housing, I can see that it has to come off to get clearance to get tstat housing off. Can I just loosen it at the Throttle body,or does it need to come off completely? I do not want to take it off completely. It appears that i can turn that squared plastic connector and pull it back from housing? Will I have enough clarance then or is there another way to do this? ?This is on a VIN L motor
Thanks
