92GrandPrixSE Posted December 11, 2011 Report Posted December 11, 2011 So, we need an alternator for the GP. We got a used one that had 61,000 on it figuring it was good. I'm taking it to the shop to test it tomorrow, but in case it's fine. I tested the cable going to the output, and I had 12 volts. How do I test the plug going to the regulator? I can't look up a wiring diagram till tomorrow. Any help will be appreciated. Quote
Addicted To Boost Posted December 11, 2011 Report Posted December 11, 2011 Bring it to an auto parts store such as Oreillys. They will put it in their testing machine and test it for you. Pretty sweet setup actually. The alt should be putting out close to 14 volts. Quote
92GrandPrixSE Posted December 11, 2011 Author Report Posted December 11, 2011 I can do that where I work with a much better machine. I'm wanting to check the wires going to the regulator. Quote
Schurkey Posted December 11, 2011 Report Posted December 11, 2011 Bring it to an auto parts store such as Oreillys. They will put it in their testing machine and test it for you. Pretty sweet setup actually. The alt should be putting out close to 14 volts. Off-the-car testing is the BEGINNING of diagnostics, not the end. Be very careful. If they don't tell you how many amps it puts out, and at what voltage; and whether there's any AC ripple voltage...they haven't done a good job. Quote
92GrandPrixSE Posted December 11, 2011 Author Report Posted December 11, 2011 Off-the-car testing is the BEGINNING of diagnostics, not the end. Be very careful. If they don't tell you how many amps it puts out, and at what voltage; and whether there's any AC ripple voltage...they haven't done a good job. That's what the tester at work does. Quote
Schurkey Posted December 11, 2011 Report Posted December 11, 2011 That's what the tester at work does. The tester (machine) is not my concern. I get nervous about the tester (person operating the machine.) Quote
92GrandPrixSE Posted December 12, 2011 Author Report Posted December 12, 2011 The tester (machine) is not my concern. I get nervous about the tester (person operating the machine.) Which would be me, lol. Quote
Garrett Powered Posted December 14, 2011 Report Posted December 14, 2011 testing the regulator? should be testing the main engine ground. the initial step to take. well, not testing, replacing if its a 92. testing the regulator is as simple as testing for 14 volts running at good idle. Quote
