Shifter23 Posted December 8, 2011 Report Posted December 8, 2011 As the title states I am looking for input on what is the better route to go in a TGP if I came across a donor. Quote
White93z34 Posted December 8, 2011 Report Posted December 8, 2011 284: + strong slightly better gearing for a tgp can use 282 style hydraulics axles are common off the shelf parts - Just TRY to buy parts for one have to make your own transmission mount if a good used one is unavaliable clutch costs 2-3x as much as 282, only company that makes performance clutches for them has god-awful customer support shift cables are made of unobtainum stock hydraulics are $TEXAS there are NO rebuild parts on the market 282: + strong tons of aftermarket support thanks to Fiero people clutches are pretty cheap and available cheap hydraulics - gearing is not ideal for LG5 shift cables are made of unobtainum axles are slightly tricky to come by Quote
intern8tion9l Posted December 9, 2011 Report Posted December 9, 2011 that's odd, i've never had a problem getting axles for my 282. granted it was never from any of the big name auto parts stores, but i've always found local transmission shops that have rebuilts Quote
White93z34 Posted December 9, 2011 Report Posted December 9, 2011 I'm just basing that of my buddy's old 88 international that for whatever reason no one could get axles in for it. Quote
Addicted To Boost Posted December 9, 2011 Report Posted December 9, 2011 Strange... I would have thought the 282s gearing would better suit the TGP than a 284 due to taller keeping the revs lower... Can definitely see why the 284 suits the LQ1 though. Quote
xtremerevolution Posted December 9, 2011 Report Posted December 9, 2011 Unless you have a COMPLETE donor car or kit from a donor car, it seems to be a better idea to just run the 282. They certainly take enough power. Quote
jman093 Posted December 10, 2011 Report Posted December 10, 2011 I'm not sure where your located, but I have a good 282 with most of the swap parts needed. I'd like 300 if interested. Parts I have are: 282 transmission clutch, flywheel, etc (engine and trans have not yet been separated) shifter and mounting brackets cv shafts shift cables Clutch fluid reservoir clutch safety switch and pigtail transmission mount Crappy old laptop pics: http://i90.photobucket.com/albums/k277/87aero/IMG000017.jpg http://i90.photobucket.com/albums/k277/87aero/IMG000021.jpg Quote
GTP091 Posted December 10, 2011 Report Posted December 10, 2011 The 284 is direct bolt up for the LQ1. I have always thought a 282 swapped on a LQ1 is a major PITA if even possible? Quote
Crazy K Posted December 10, 2011 Report Posted December 10, 2011 The 284 is direct bolt up for the LQ1. I have always thought a 282 swapped on a LQ1 is a major PITA if even possible? it's possible, it was done by Badflash to his 90 lumina, but I would imagine the gearing would not be optimum. why does the clutch and shit gotta be so different between a 282 and 284? has anyone ever test fit the opposite clutch and pressure plate into the opposite tranny? Quote
Shifter23 Posted December 10, 2011 Author Report Posted December 10, 2011 Good info to know. I just picked up a 91 GTP 5-speed which of course runs the 284 and I am going to preserve it. But I still was asking due to the fact I do want to swap a TGP sometime since I have a couple I figured it would be nice. The TGP would be a lot more fun on the street with a 5-speed. Lucky that from what I am hearing my 284 is a GM reman and has a fresh clutch 20K ago. So other than making sure my LQ1 stays top notch and I don't beat the hell out of it I should be good. Quote
Bake82 Posted December 10, 2011 Report Posted December 10, 2011 I have a 282 behind a LQ1 and it's fun! Maybe not as good as a 284 but WAY better than an automatic. The ONLY problem with the swap was the rear engine mount bracket. You NEED the one from the 284 or you need to fabricate something to work to hold the intermediate shaft and replace part of the engine mount support you need to cut out of the automatic engine mount bracket. Besides that it bolts up exactly as a 284 would and runs damn good! Quote
