TTThornhill Posted December 4, 2011 Report Posted December 4, 2011 Hello All, ran into an Odd problem that just happened. on my 1998 GT,(3.8 180k miles) I performed the following things at service oil & filter change (went from 5w-30 to 10w-30) replaced pcv valve seafoam treatment of valves and crankcase after I did the following I have noticed that upon startup, the car will puff some white smoke that has a fuelish smell to it. then it goes right away and doesnt happen til the car cuts off and sits for a while. everything drives just as good as before and there are no codes on dash. The car never had any smoke issues until i performed this service. Also, I am having some kind of screeching sound that happens randomly. I think i might of gotten some oil on the manifold then it got slung onto some of the pulleys. it sounds like it was coming from the compressor area. but not to sure yet. It will only happen around 800 - 1500rpm and when going slow. I pressure washed that area off and it went away, but came back the next day. I doesnt sound like a typical belt squeal, almost sounds like metal on metal. I know this would be hard to get any help on, but i just wanted to throw that in there. any help will be appreciated! Quote
94 olds vert Posted December 4, 2011 Report Posted December 4, 2011 If you put sea-foam in your car, it's going to smoke. Quote
TTThornhill Posted December 4, 2011 Author Report Posted December 4, 2011 this is 2 days after the fact and over 100 miles of driving. Quote
94 olds vert Posted December 4, 2011 Report Posted December 4, 2011 Did you put it in the crank case? Quote
TTThornhill Posted December 4, 2011 Author Report Posted December 4, 2011 yup and only had it in there for about 10 minutes of driving before i changed the oil Quote
94 olds vert Posted December 4, 2011 Report Posted December 4, 2011 Then the seafoam is not the problem. Quote
ScoobyDoo82 Posted December 4, 2011 Report Posted December 4, 2011 Then the seafoam is not the problem. I'm pretty sure he knew this. How severe does the smoking get, just little puffs or is it plumes? As for the grinding/scraping it might be your water pump or compressor starting to take a poop. I doubt anything you did caused this, its probably just timing. Quote
Mel87 Posted December 4, 2011 Report Posted December 4, 2011 Need more detail on the smoke coming out to be able to try to diagnose it. As for the screeching, that could be number of things as well. Dry belt, bad AC compressor bearings, or even the pulley going bad. Quote
TTThornhill Posted December 4, 2011 Author Report Posted December 4, 2011 i guess you could consider it a small plume. it will do it just for about 10 seconds then stop. its kinda like the seafoam effect but just very short. the cloud will travel all the way from front yard to back. Quote
brake Posted December 4, 2011 Report Posted December 4, 2011 can you pressure test the cooling system? Quote
TTThornhill Posted December 4, 2011 Author Report Posted December 4, 2011 yea ill try to get my hands on a tester in the next couple of days. I did replace just my upper intake gasket about 3 months ago. but I have not noticed any loss of coolant recently. Quote
brake Posted December 5, 2011 Report Posted December 5, 2011 yeah i'd pressure test it and probably check the fuel pressure as well. Quote
TTThornhill Posted December 5, 2011 Author Report Posted December 5, 2011 well here is an update so far. it is nothing on the pulleys. I took off the belt for a second and it still squealed. when running, I removed the oil cap (which seem to had a good bit of suction, everyone at my shop says that it more than normal) and the sound will go away, but the cap on and 2 seconds later is starts right back up. I purchased another PCV valve and it still does the same thing. I still have not been able to get my hands on a pressure tester ( i work at a diesel shop and everythings is a little big) Quote
Andrew Posted December 6, 2011 Report Posted December 6, 2011 Heavy white smoke is usually an indication of burning coolant. i would inspect the upper plenum around the egr port, super common to fail there. Should replace it with the improved design and smaller stovepipe no matter what. Quote
TTThornhill Posted December 6, 2011 Author Report Posted December 6, 2011 problem solved, found that i was missing an Oring on the PCV valve itself. without it, it was causing high crankcase pressure resulting in the odd squeal. Quote
