Bake82 Posted November 18, 2011 Report Posted November 18, 2011 After my 5spd swap I closed up my glove box and now it won't open. It has the locking mechanism on it. The owner's manual says you need a special key to do this which should be with the car so you can unlock and then change the code. Ofcourse it's not and I never was given the code to begin with. How can I get into the glove box short of breaking shit? Thanks! Kyle Quote
AL Posted November 18, 2011 Report Posted November 18, 2011 I know its possible without breaking anything, do a quick search as this has come up a few times, I just dont remember the solution that was posted Quote
White93z34 Posted November 18, 2011 Report Posted November 18, 2011 those are easy. get a small flashlight and look between the numbers, primarily to the right of each number you will see little teeth in next to the number wheels slowly turn them one at a time. I go left to right. and keep turning till the teeth go away, repeat for each number then it should open up no problem and you'll have the code that you can then reset to your liking. Quote
94 olds vert Posted November 18, 2011 Report Posted November 18, 2011 What Chris said that method works great. I had to do that. Quote
Bake82 Posted November 18, 2011 Author Report Posted November 18, 2011 Thanks Chris! knew it was easy just ddn't know what I had to do! Will give it a shot tonight!! Quote
revnrob Posted November 18, 2011 Report Posted November 18, 2011 My buddy had a lock like that in his old car,,,it was like 000 or 111 ,,, some combo that was all the same!!! Quote
White93z34 Posted November 18, 2011 Report Posted November 18, 2011 by default they are 000 but customizable to whatever you wanted Quote
intern8tion9l Posted November 19, 2011 Report Posted November 19, 2011 is it dumb to ask how to reset? Quote
ScoobyDoo82 Posted November 19, 2011 Report Posted November 19, 2011 is it dumb to ask how to reset? Put your code in, open the glovebox, push the orange "button" up, put in your new code, push the button back down, test it, close the glove box, done. Quote
Bake82 Posted November 27, 2011 Author Report Posted November 27, 2011 Thanks Chris! Glove box unlocked! previous owner never changed it...0 0 0! Quote
