AMP Posted November 16, 2011 Report Posted November 16, 2011 so the GTP has only water in it and it is suppose to get down to 27 tonight would it be fine or should i get my ass out there and put antifreeze in it? Quote
94 olds vert Posted November 16, 2011 Report Posted November 16, 2011 Yeah. Freezing water in your cooling system is bad. Quote
AMP Posted November 16, 2011 Author Report Posted November 16, 2011 Yeah. Freezing water in your cooling system is bad. yeah i figured i should but did not now cuz it is just a little under freezing Quote
xtremerevolution Posted November 16, 2011 Report Posted November 16, 2011 Yeah. Freezing water in your cooling system is bad. Anthony found that one out the hard way. He thought he blew head gaskets when he really only blew the freeze plugs, and iirc the radiator too. Might want to take care of that... Its spelled coolant btw. Sent from my HTC Awesome using Tapatalk Quote
AMP Posted November 16, 2011 Author Report Posted November 16, 2011 Anthony found that one ou the hard way. Thought he blew head gaskets when he really only blew the freeze plugs, and iirc the radiator too. Might want to take care of that... Its spelled coolant btw. Sent from my HTC Awesome using Tapatalk yeah coolant i know dont know why i spelled it like that. Quote
Addicted to eaton Posted November 17, 2011 Report Posted November 17, 2011 (edited) at 27 its a gamble.. Id change it out Wanna know why? I did this, and the cold won http://www.w-body.com/showthread.php/43686-The-end-is-near. edit: I hit post then went lookin for the link. I did not notice he posted it already. I thought i cracked the block, But it did bust front And back freeze plug out. I unded up useing the motor in the 1999. (after going threw it a little). Still never felt safe about it after that. Edited November 17, 2011 by Addicted to eaton Quote
AMP Posted November 17, 2011 Author Report Posted November 17, 2011 well got it done it had Pink antifreeze i did not notice it, it looked clear like water to me but i started to drain it and notice it was pink so i topped it off and called it good.:lol: Quote
xtremerevolution Posted November 17, 2011 Report Posted November 17, 2011 well got it done it had Pink antifreeze i did not notice it, it looked clear like water to me but i started to drain it and notice it was pink so i topped it off and called it good.:lol: Pink? The only color these cars were supposed to use is orange or green. Sent from my HTC Awesome using Tapatalk Quote
AMP Posted November 17, 2011 Author Report Posted November 17, 2011 i believe it is the kind you can mix with any kind and color cuz my old lumina had the same. it does not overheat and it runs fine so. Quote
Addicted to eaton Posted November 17, 2011 Report Posted November 17, 2011 pink is normally for rv's/ boats. and uh, Auto coolants have special lubricants added to keep seals soft and the water pump lubed. They also have tons of anti-foaming, anti-corrosive, and anti-electrolysis additives. Put the RV stuff in your vehicle and the electrolysis damage also can destroy your radiator and heater core. Quote
AMP Posted November 17, 2011 Author Report Posted November 17, 2011 well my old lumina my dad had it before me and had put the pink in all the time and it has no problems, and it is the kind the mixes with what ever antifreeze. Quote
xtremerevolution Posted November 17, 2011 Report Posted November 17, 2011 well my old lumina my dad had it before me and had put the pink in all the time and it has no problems, and it is the kind the mixes with what ever antifreeze. Just because it hasn't failed before, doesn't mean its a good idea. Its a matter of preventative maintenance. If its the kind that is guaranteed to mix with other automotive antifreeze types, then you should be alright. Quote
AMP Posted November 18, 2011 Author Report Posted November 18, 2011 Just because it hasn't failed before, doesn't mean its a good idea. Its a matter of preventative maintenance. If its the kind that is guaranteed to mix with other automotive antifreeze types, then you should be alright. yeah i look at what my dad has and it is the same stuff so it is good. Quote
