BN Posted November 13, 2011 Report Posted November 13, 2011 Car is prewired, I found the plug behind the dash. Problem is with the two temp sensor wires B4 Grn/Blk and B7 Yellow. Both wires are present in the plastic plug that plugs into back of DIC but I don't find the other end that plugs into sensor near the grille. Anyone know if I might find the plug hidden somewhere or do I need to run two new wires. BTW the sensor is not on the radiator support but I have a new one. Quote
94 olds vert Posted November 13, 2011 Report Posted November 13, 2011 Huh, it should be there tucked up in the factory head light wires. Did you check where I showed you? Quote
BN Posted November 13, 2011 Author Report Posted November 13, 2011 Yeah, looked all around there unless it's inside the black plastic conduit stuff. PM'd with Addicted to eaton and he said he had the wires on the plug but could never find the other end either, so he ran new. I'm thinking of running new wires and putting the sensor in the rocker panel so I don't have to try to get through the firewall. Quote
AL Posted November 13, 2011 Report Posted November 13, 2011 There was someone else trying this same thing, Ken posted about where the wires stop so you wont have to run completely new wires Quote
BN Posted November 14, 2011 Author Report Posted November 14, 2011 Ended up running a new one for the sensor and it now works. Quote
