Demented Monte Posted November 10, 2011 Report Posted November 10, 2011 (edited) Does anyone know how to remove the dash pad from a 95 - 99 Monte Carlo? I found one at a local junkyard that hasn't sun warped yet and i need to know how to get it off... Anyone's help would be much appreciated!!!!!!!!!! Edited November 10, 2011 by Demented Monte Spelling correction. Quote
Demented Monte Posted November 16, 2011 Author Report Posted November 16, 2011 Ok if noone has any idea how to do that....Does anyone know the best method to fix the dash when it warps right about the gauge cluster?? Quote
AL Posted November 16, 2011 Report Posted November 16, 2011 I dont think its a dash cover, but the whole dash itself... Its about 4 big bolts along the bottom of the windshield and two by each door... If you wanna pull your whole dash I can post the write up Quote
Demented Monte Posted November 16, 2011 Author Report Posted November 16, 2011 Well if thats what i gotta do and you don't mind posting it. Quote
3pt1lumina Posted November 17, 2011 Report Posted November 17, 2011 The piece around the gauges? Like with the vents in it? Unscrew the panel below the steering wheel (2 screws) then just pull it off gently. If you mean the entire dash, I've never pulled one completely out of a 1.5 gen so you'll have to wait for someone to do a write up. Quote
Demented Monte Posted November 17, 2011 Author Report Posted November 17, 2011 Unfortunately 3 that's exactly what i meant lol. Quote
AL Posted November 17, 2011 Report Posted November 17, 2011 REMOVE OR DISCONNECT 1. Battery ground (negative) cable. 2. Front door inside carpet retainers. 3. Instrument panel insulators. 4. Disable SIR system. 5. Windshield side upper garnish moldings. 6. Instrument panel upper trim panel. 7. Instrument panel compartment. 8. Passenger side SIR inflator module. 9. Steering column opening filler. 10. Instrument panel cluster trim plate. 11. Front floor console, if equipped. 12. Audio system. 13. Heater A/C control. 14. Instrument panel cluster. 15. Headlamp switch. 16. Fuse block. 17. Instrument panel knee bolster bracket. 18. Steering column. 19. Bolts/screws from instrument panel trim pad mounting. 20. Data link connector. 21. Instrument panel compartment lamp. 22. Wiring harness clips from instrument panel trim pad. 23. Reposition instrument panel wiring harness. 24. Instrument panel trim pad from vehicle. INSTALL OR CONNECT NOTE: Refer to Fastener Notice in Cautions and Notices. 1. Instrument panel trim pad to vehicle. 2. Route instrument panel wiring harness. 3. Wiring harness clips. 4, Data link connector. 5. Instrument panel compartment lamp. 6. Bolts/screws to instrument panel trim pad mounting. Tighten * Bolts/screws to 10 Nm (89 lb in). 7. Steering column. 8. Instrument panel knee bolster bracket. 9. Fuse block. 10. Headlamp switch. 11. Instrument panel cluster. 12. Audio system. 13. Heater A/C control. 14. Instrument panel cluster trim plate. 15. Front floor console, if equipped. 16. Steering column opening filler. 17. Passenger side SIR inflator module. 18. Instrument panel upper trim panel. 19. Windshield side upper Garnish moldings. 20. Enable SIR system. 21. Instrument panel insulators. 22. Front side door inside carpet retainers. 23. Battery ground (negative) cable. Quote
AL Posted November 17, 2011 Report Posted November 17, 2011 No problem... Good luck with the swap! Quote
