Nicely Cruising Along and then engine died (93 Z34)
Coming home from work @ 1:00 am and five blocks away from home and all of a sudden as I stepped on the gas, nothing! So I just let it roll until it stopped. I placed on park or neutral, turn the key, it will crank but not start or turnover. What's the problem? fuel pump - is it time? it's still OEM that's in there. Just a little history --- it died while I was driving before also maybe 4 or 5 times, especially when I pull in to a parking lot that will require me to step on the brake and turn the wheel at the same time, hhhhmmmnnn? Any ideas are always welcome and accepted.
Thanks!:think:
Do you have a remote starter? I put a t-harness in for a remote start that wasn't fitting worth a shit and had my car die in the middle of the road.
^^ Doubtful this is the issue.
Sounds like you are having an issue with a load being pulled at low or idle rpms.
How long since your last tuneup?
No idon't but i replaced the fuel pump and I'm back on the road again. Thanks.
6 months ago. But i replaced the fuel pump and I'm back on the road again. Thanks.
No problem. I guess after 18 yrs, it's time for a new one. I stayed with AC Delco - maybe it'll give me another 18 years.
