performance shift
hello all , i am new to this board and would like to say thank you in advance for any help given and i will try and help anyone as well.
three days ago i purchased a 1999 buick rega LSl , it has 39,000 miles on it and it is in excellent condition. it has a light on for the performance shift showing it is on, in the manual it states there is a button on the shifter to turn this feature on and off. the is no button on the shifter and i can not find any way to turn this on or off. any one have any ideal how to turn this on or off ???
Thanks , Jason
Performance Shift was a GS/GTP only thing. The only reason it should be illuminated is if someone grounded pin 21 on the PCM for some reason.
its def on, any way to get it off ? what is pin 21 and pcm ?
The pcm in the powertrain control module and the pin is in one of the connectors to the pcm... the pcm is in the airbox
