skitchin Posted January 3, 2013 Author Report Posted January 3, 2013 I know my setup varies slightly from others, but was gonna say if ride quality is at all important to you, get some progressive rate coils(QA1 I believe makes some). I'd say 300lbs is pretty much the upper range of what you want to run in a daily driver, especially with stock spring rates in the front. Now, granted I have front and rear strut braces, but the 300lbs springs are biased enough to create over-steer in wet conditions if I'm not careful with shifting my momentum around. I'd say a better spring rate for comfort would be right around 200-225. AFAIK, spring rates measure how many lbs to compress the spring 1 inch, so 100lbs more in the engine bay may not translate exactly to 50lbs more in each spring's rate. Quote
l67ss Posted January 3, 2013 Report Posted January 3, 2013 the other factor is im planning on starting with a pretty beat car ie wrecked Quote
19Cutlass94 Posted January 3, 2013 Report Posted January 3, 2013 I know my setup varies slightly from others, but was gonna say if ride quality is at all important to you, get some progressive rate coils(QA1 I believe makes some). I'd say 300lbs is pretty much the upper range of what you want to run in a daily driver, especially with stock spring rates in the front. Now, granted I have front and rear strut braces, but the 300lbs springs are biased enough to create over-steer in wet conditions if I'm not careful with shifting my momentum around. I'd say a better spring rate for comfort would be right around 200-225. AFAIK, spring rates measure how many lbs to compress the spring 1 inch, so 100lbs more in the engine bay may not translate exactly to 50lbs more in each spring's rate. 200-225lbs in the rear is WAYY too soft. I was bottoming out with 250lbs springs. I wouldnt go any lower in the rear than that IMHO Quote
AWeb80 Posted January 3, 2013 Report Posted January 3, 2013 I have 250's and want to swap to 300's Quote
skitchin Posted January 4, 2013 Author Report Posted January 4, 2013 Do ya'll have 12" or 14" springs? Quote
Psych0matt Posted January 4, 2013 Report Posted January 4, 2013 (edited) I have 10" on the front and 14" on the rear of mine. the 10"s were just too short. Adjusted all the way up and I was still mad scraping, and not in a good way. 14"s gave me a perfect amount of travel both ways (10"s on the front were perfect) Id have to look through my threads, but I think I did 350 and 400 and its solid but still comfy enough to drive (although I have comfy aq9s too ) EDIT: 400 front, 350 rears Edited January 4, 2013 by Psych0matt Quote
19Cutlass94 Posted January 4, 2013 Report Posted January 4, 2013 I run 12" springs in the rear. Have plently of adjustment. Quote
skitchin Posted January 4, 2013 Author Report Posted January 4, 2013 Custom or stock upper mounts? Quote
AWeb80 Posted January 4, 2013 Report Posted January 4, 2013 I run 12" springs in the rear. Have plently of adjustment. I have the old FFP mounts. x2 Quote
Rocketman Posted May 3, 2013 Report Posted May 3, 2013 Bump. Finished mine today. Just so y'all know the isolators are available from summitracing, don't have to go anywhere special http://www.summitracing.com/parts/ens-9-6103r I decided to make my own sleeves as I don't need adjustment, saved some cash. I cast them & machined for both the top & bottom. Went with 300lb springs. No more sag, mine was particularly bad. Might have to trim the perches a bit but it's so much better than it was before Before (after I emptied the trunk of tools & parts) After -Rocket Quote
