alfi1 Posted October 21, 2003 Report Posted October 21, 2003 hi everybody i want to change my cranksensor on my lumina 1991 v6 3.1 vin t i have 3 questions 1- where is the exact location for the sensor? 2- can i do the job without remove the crank pulley? 3- what is the best way to access the sensor? thank to answer alain Quote
Aaron Posted October 21, 2003 Report Posted October 21, 2003 now i have a 92 Lumina with the 3.4, and a manual, but ti should be close to the same. mine was on the back of the block, about 3" up from the oil pan. it looks like a plug, that L's to dive into the block and has 1 8 or 10mm bolt holding it in place. undo the bolt, and pull it out, it should be around 2" long. Quote
cmo1234 Posted October 21, 2003 Report Posted October 21, 2003 Yup that is about right for the 3.1 also. Its in the back and there are 2 sensors down there next to each other. The cranksensor is the one lower and more in the middle. You can access it from the top (removing alternator really helps) to undo the screw. You can reach it from the bottom also (i have) you have to snake your arm up behing the (frame-sub frame) whatever that is down there and then its maybe easier to pull out that way if you cannot get at it from the top. Do a search on crank position sensor there is more detailed info somewhere else Quote
fast68 Posted October 22, 2003 Report Posted October 22, 2003 back of the block ? how can alternator be in the way if its on back of block ? you mean back sideof front end, or back end of block ? hmm thanks Quote
Robby1870 Posted October 22, 2003 Report Posted October 22, 2003 back of the block ?how can alternator be in the way if its on back of block ? you mean back sideof front end, or back end of block ? hmm thanks If you take the alternator and bracket, you can reach right down to the back of the block and get to the sensor from the top of the motor. The sensor is on the back of the block, right where they said Quote
alfi1 Posted October 24, 2003 Author Report Posted October 24, 2003 thank for the help guy's i think that the cranksensor mounted just beside the crank pulley i see that on many gm alain Quote
Aaron Posted October 24, 2003 Report Posted October 24, 2003 thank for the help guy's i think that the cranksensor mounted just beside the crank pulley i see that on many gm alain mine is no where near my pulley, its closer to the tranny. Quote
kadoi Posted October 25, 2003 Report Posted October 25, 2003 i have a 3.1 also (v) and mine is right where aaron said Quote
