valeck25 Posted November 1, 2011 Report Posted November 1, 2011 who knows of someone that could fix my TGP in the chicago land area i have tryed everything execept replacing the tps in it and the idle keep acting up. at first start its normal but after driving the idle stays high idk how high because of the gauges but it sounds high and if i turn it off and back on it idle normal. if some one here could help me please please im getting ready to take it to the stealership lol. Quote
Bake82 Posted November 1, 2011 Report Posted November 1, 2011 Crossover been replaced? if it's a stock crossover it's leaking and most likely causing issues! Quote
White93z34 Posted November 1, 2011 Report Posted November 1, 2011 sounds like its doing nearly the exact thing to a t that my old tgp did with a broken crossover pipe. Quote
valeck25 Posted November 1, 2011 Author Report Posted November 1, 2011 Yeah I replaced it with a stock one last year and it was running beautiful this problem started right around march. Quote
White93z34 Posted November 1, 2011 Report Posted November 1, 2011 are you sure its not leaking again? no excessive exhaust noise under hood? save for that maybe a screwy o2 sensor? Quote
valeck25 Posted November 1, 2011 Author Report Posted November 1, 2011 Nope no leaks there, the O2 sensor was a lil loose I just tighten it and that helped with the boost alot , just yesterday I did the idle relearn like 10 times lol and no luck unless I'm doing something wrong. Quote
Garrett Powered Posted November 1, 2011 Report Posted November 1, 2011 broken egr tube is the same thing as bad xover Quote
valeck25 Posted November 1, 2011 Author Report Posted November 1, 2011 I didnt even think of it I will check that and maybe replace the egr. Thanks Quote
valeck25 Posted November 1, 2011 Author Report Posted November 1, 2011 Ok I checked for leaks by ear lol and it sounds like a small leak by the egr tube but then again it could be the downpipe. This problem is making me hate my TGP Quote
intern8tion9l Posted November 2, 2011 Report Posted November 2, 2011 rebuilt(not stock) crossover and egr delete Quote
valeck25 Posted November 2, 2011 Author Report Posted November 2, 2011 where can i get an egr delete or how do i make it? thanks Quote
valeck25 Posted November 3, 2011 Author Report Posted November 3, 2011 Ok lil update I finally decided to take the cap off the adjuster screw in the throttle body and move it, that seem to help we'll see what happens over the next few days. Quote
White93z34 Posted November 3, 2011 Report Posted November 3, 2011 no real point in deleting the EGR IMO, just makes the SES lamp come on more often with no real marketable gains. and adjusting the throttle stop screw is masking the problem at best. Â There is no good reason to replace a broken crossover with another stock crossover as that happens to all of them. There are still folks who rebuild them to better then factory spec, PM GOT2B GM he has a jig for rebuilding them and a thread in the FS section just for that service. These cars need a little more special care then the average 3.1 grand prix. Quote
GOT2B GM Posted November 3, 2011 Report Posted November 3, 2011 Yes, give me a reason to buy another welder!!! Quote
valeck25 Posted November 3, 2011 Author Report Posted November 3, 2011 Lol nice, I paid over 200 for that pipe just last year didn't even know about you guys til later. So how much would a new pipe be and what would you need? Thanks Quote
intern8tion9l Posted November 3, 2011 Report Posted November 3, 2011 no gains from egr delete, i know that. i mean if it were leaking i'd just do away with it. will require chip modification though Quote
valeck25 Posted November 11, 2011 Author Report Posted November 11, 2011 another update on this problem, i just seafoamed it and i saw a little bit of smoke come out from the x-over to turbo, and front manifold to x-over, so there is a little leak, would this cause the high idle? thanks for the support. Quote
Bake82 Posted November 12, 2011 Report Posted November 12, 2011 yes it could. Fix the leak first. If it doesn't fix the problem it's something else which it definetly could be BUT but the leak isn't helping. Quote
