Laveen Z34 Posted October 26, 2011 Report Posted October 26, 2011 My 93 Z34 dies or attempts to die when engine is cold. Any ideas why? But once it warms up everything is good. Quote
Artemis Posted October 26, 2011 Report Posted October 26, 2011 Do you rev it higher to stop it from stalling? Quote
Laveen Z34 Posted October 27, 2011 Author Report Posted October 27, 2011 Do you rev it higher to stop it from stalling? Yes. Initially after it stalls. But like what I said, once it warms up, it's all good.... Quote
Psych0matt Posted November 1, 2011 Report Posted November 1, 2011 just did my upper and lowers a few months back, fixed so many little problems Quote
Galaxie500XL Posted November 1, 2011 Report Posted November 1, 2011 Bad coolant temp sensor. The engine is running lean, becuase the temp sensor thinks the engine is warmer than it really is. Check with a scantool...let the car sit overnight. Coolant temp reading from the scantool should be very close to actual air temp. I'm betting you'll find that the sensor is reporting the temperature at least 20 degrees warmer than the actual coolant temp. Quote
