intern8tion9l Posted October 19, 2011 Report Posted October 19, 2011 i have intrax front springs and kyb gr2 struts. i'm having a serious problem with the tires rubbing the top of the fender going around turns or even hitting bumps in the road. anyone else have this problem or who has dealt with it before? Quote
jman093 Posted October 19, 2011 Report Posted October 19, 2011 I had zero rubbing problems in the front when the car was slammed on its lowering springs (running cut FE3's now), but I'm running 225/50R16 tires which are a bit shorter than the stock 225/60R16 size, although the performance tire I have is almost an inch wider than most 225's. Quote
MiriV Posted October 19, 2011 Report Posted October 19, 2011 roll the fenders. heat gun + rubber mallet. get the fender hot to the touch and hammer away on the inner lip. there are youtube videos of that. intrax are pretty damn low, im not suprised u rub. Quote
Garrett Powered Posted October 19, 2011 Report Posted October 19, 2011 (edited) I had intrax on the black tgp and took them right back off. I put on some 94 MC springs I got from rock auto and it dropped it maybe an inch. I might cut off a coil. I am thinking the intrax springs would work well on the 88 without the body kit and fender flares the tgp has. smaller tires are always an option. Edited October 19, 2011 by Garrett Powered Quote
GOT2B GM Posted October 19, 2011 Report Posted October 19, 2011 I'm running Intrax's on my TGP with 245-45-16s no issues Quote
intern8tion9l Posted October 20, 2011 Author Report Posted October 20, 2011 what the crap. i'm gonna have to try some sort of bending, it's pretty embarassing going around a corner Quote
GhrarhG Posted October 20, 2011 Report Posted October 20, 2011 I'm running Intrax up front on my 88, no rubbing issues here with 245/50/16s on X-laces. What wheels and tires are you running? Quote
xtremerevolution Posted October 20, 2011 Report Posted October 20, 2011 I'm with the guy above. What *exact* tires are you running? All 245x50x16 tires are not made equal. The 245 is only the section width. With regard to drop, I'd say do what everyone else said and roll the fenders. Silly fenders though, I have a <holy shit that's low> drop on my Regal and I don't rub anything, and by low I mean I have maybe 2" of travel left. They are pretty stiff springs though. Quote
intern8tion9l Posted October 21, 2011 Author Report Posted October 21, 2011 tires are yokohama 245/50/16 on factory laces. i did a little hammering and trimming (tires already wore through the flares along the top) today. seems to have helped a lot, but still hitting a little bit on the driver's side Quote
xtremerevolution Posted October 21, 2011 Report Posted October 21, 2011 tires are yokohama 245/50/16 on factory laces. i did a little hammering and trimming (tires already wore through the flares along the top) today. seems to have helped a lot, but still hitting a little bit on the driver's side Must be a GP specific issue. My car is so low that I can *barely* slide my low profile jack under the subframe. I kinda have to wedge it in there. Quote
AWeb80 Posted October 21, 2011 Report Posted October 21, 2011 I don't have Intrax, but ST's. With my 245/50's I had to use a rubber hammer to tap the inner metal lip on the fender up and out of the way. Now I run 1/8" spacers w/ NO problems. Maybe some of these cars are made a bit different.....but I'm sure GM's tolerances are/were spot on...LOL Quote
intern8tion9l Posted October 22, 2011 Author Report Posted October 22, 2011 Must be a GP specific issue. My car is so low that I can *barely* slide my low profile jack under the subframe. I kinda have to wedge it in there. yeah i had no issues on my cutlass with this exact suspension Quote
Garrett Powered Posted October 25, 2011 Report Posted October 25, 2011 I'm with the guy above. What *exact* tires are you running? All 245x50x16 tires are not made equal. The 245 is only the section width. With regard to drop, I'd say do what everyone else said and roll the fenders. Silly fenders though, I have a <holy shit that's low> drop on my Regal and I don't rub anything, and by low I mean I have maybe 2" of travel left. They are pretty stiff springs though. Ghargh has an 89 without the fender flares. tgp only, most likely need low profile 45 series because it has steaks for a stock size tire, AND body kit. so more like a TGP specific thing. 45 series are low profile tires but also the tread is thinner if you measure it in real life even though they say 245, believe it or not. they are alot smaller and thus, less traction. Quote
Garrett Powered Posted October 25, 2011 Report Posted October 25, 2011 tires are yokohama 245/50/16 on factory laces. i did a little hammering and trimming (tires already wore through the flares along the top) today. seems to have helped a lot, but still hitting a little bit on the driver's side I am probably going with cut tgp springs on my black car so I can stay not rubbing those 265's on the body kit. my intrax didn't seem to fit with big tires. I wondered if I could get custom spacers to lift it slightly because I wanted thicker intrax springs but don't see how that would be possible. yeah my stance could be better.... but honestly its probably staying like it is. Quote
