What do I need to install HUD?
Found a hud unit on ebay. Its just the dash top display box. What else do I need? The car is a 94 CS Vert., built 10/93. I understand some cars are pre wired and some are not, what are the chances mine is? Thanks.
Well, your build date is close to mine and my 94 was prewired. Remove the bezel around the gauges and light switch. 5 screws hidden on the top lip. Then behind the cluster or light switch look for an extra wire connector. It will be blue and kinda big. If it's there your car is prewired.
Do you have the 3.4 DOHC with steering wheel controls and ECC? If so the odds are good it's prewired.
You will need dash pad, HUD unit, dimmer/adjuster switch (you must have that) also will need the smaller cubby in the center stack.
The dash pad is optional. You will have to cut out material for the HUD.
My car has all of the above. I hope it is :-), but i still need to find the switch, dash pad and cubby.
if its not pre wired its not to hard to install one you can do it the lazy and half assed way. Or the right way (i have did both) they both took about the same time
and the donor car
Its really about 3-4 hours of work the right way
