3pt1lumina Posted October 14, 2011 Report Posted October 14, 2011 My dad's 95 Brickyard Monte has the infamous 3.4 and I have been chasing an issue all summer, and I'm officially out of ideas. Some back story. Has 86k on it, before we got it the previous owner only put 1500 miles on it in 5 years. Since May, my dad's put on about 3k. When we first got it when you would take off it would have a bad stumble then go. Idle was kind of funny, especially cold. So I replaced the TPS and the stumble went away but the car still idled funny when cold. So I cleaned the IAC, no difference. Replaced it, ran worse. Put the old one back in, runs about the same as before. I've checked for vacuum leaks, the PCV line was so so replaced that and the PCV, still no difference. When the car is cold, it runs terrible. It will tach up to about 3k and slowly come down, with a terrible idle. If you drive it for about 2 mins and come to a stop it will run like it's going to stall. Drive it a bit more and get it warmed up, runs fine. One other thing I notice, when you are in park and go to tap the gas (like revv it up a little) it takes a long time (15-20 seconds) for the idle to come back down to 900 or so. HELP! I want to get this resolved before we store it for the winter. I honestly have no idea if the plugs/wires have been done. The front wires are red, backs are gray, Belden wires are what's on there...don't think those were OEM. Thanks in advance! Quote
95 vert Posted October 14, 2011 Report Posted October 14, 2011 Man, sounds like the intake gasket is leaking. Same issue I had with one of mine. Quote
urbex Posted October 14, 2011 Report Posted October 14, 2011 Contrary to what I have done, I'd start with the cheaper items first and work from there. I'd look at plugs/wires first. Maybe coil packs too? Quote
nitehawkjcb Posted October 14, 2011 Report Posted October 14, 2011 Check your fuel pressure. Filter might be clogged, or the pump could be weak. Couldn't hurt to change the spark plugs and wires. Quote
AL Posted October 14, 2011 Report Posted October 14, 2011 Man, sounds like the intake gasket is leaking. Same issue I had with one of mine. I agree, Buck had the same issue with my old 91 Quote
Addicted to eaton Posted October 14, 2011 Report Posted October 14, 2011 I agree, Buck had the same issue with my old 91 was about to say the same thing. Sounds like its getting air its not accounting for (just like my impala was) Quote
White93z34 Posted October 14, 2011 Report Posted October 14, 2011 those are napa wires. It sounds kind of like an intake gasket leak to me if its idling that high when cold. check your booster hose as well. Quote
3pt1lumina Posted October 14, 2011 Author Report Posted October 14, 2011 You know... I never thought of the intake gaskets. How hard are they to do on this engine? I think it will need plugs/wires anyways as that was something we were going to do, as well as a Timing Belt in the spring (since I don't know how old it is). Chances are what I'll do is maybe do it all at once. Finding a few little gremlins from it sitting so long. That's why I drive the hell out of whatever I have! Quote
Schurkey Posted October 15, 2011 Report Posted October 15, 2011 Put a scan tool on this thing (a REAL tool, not some cheap-junk code reader) and look for issues. Does the coolant temp sensor provide accurate data? What is the short- and long-term fuel correction when the engine is idling bad? O2 sensor seem to provide valid data? Quote
Crazy K Posted October 15, 2011 Report Posted October 15, 2011 Your symptoms definitely sound like a bad intake gasket. i have had the same issue with a 95 LQ1 and the intake gasket fixed it. You can try the spray carb cleaner trick to see if it will isolate the gasket leak.... Quote
New Age Monte Posted October 16, 2011 Report Posted October 16, 2011 An update.....The engine has developed a slight coolant leak from what appears to be the front of the engine. Could be a gasket. Quote
New Age Monte Posted October 22, 2011 Report Posted October 22, 2011 Your symptoms definitely sound like a bad intake gasket. i have had the same issue with a 95 LQ1 and the intake gasket fixed it. You can try the spray carb cleaner trick to see if it will isolate the gasket leak.... Assuming it's an intake gasket, would it be easier to replace the timing belt at the same time (to save on labor)? Quote
BrianK82 Posted October 23, 2011 Report Posted October 23, 2011 Replacing the lower intake manifold gaskets has no bearing on the timing belt. Two completely separate procedures. Quote
GEN1Z34 Posted October 25, 2011 Report Posted October 25, 2011 Before you throw parts @ it I would locate and correct the coolant leak.. Then have the timing belt changed since it should have been done @ 60K especially if you're still running the original belt and if you're hard on it.. No offense but I would have a professional change the belt as it does'nt seem like you're overly familier with the LQ1.. After the belt is changed, if symtoms persist, I would do as mentioned and have it scanned with the proper scan tool.. Most auto parts stores such as Advance will scan it for free.. Simply throwing parts @ it is never really a good idea.. Just my .02 Quote
