chadz34 Posted October 3, 2011 Report Posted October 3, 2011 Noticed, my wheel had some play in it, took the tire off, and the trailing arm was literally snapped in half . Pics to follow Quote
tornado_735 Posted October 3, 2011 Report Posted October 3, 2011 Good thing you caught it. It's a fairly simple repair. If you can't get the bolt out of the body mount, your best bet is an air hammer or a cut-off wheel. I am pretty sure like, Advance or AZ have a decent replacement set for less than a hundred bucks. Someone here was talking about them not too long ago. Quote
BXX Posted October 3, 2011 Report Posted October 3, 2011 Rockauto, look up like a 2000 Impala for the trailing arm, get the Dorman unit which is a boxed trailing arm. I think they are $12 each:thumbsup: Im too lazy to look up teh part number though:lol: Quote
chadz34 Posted October 3, 2011 Author Report Posted October 3, 2011 Wasn't even in bad shape....makes me wonder.... Quote
BXX Posted October 3, 2011 Report Posted October 3, 2011 Wasn't even in bad shape....makes me wonder.... They are damn near made out of cheap sheet metal. Hell I think the sheet metal making the body panels is stronger:lol::lol: Quote
chadz34 Posted October 3, 2011 Author Report Posted October 3, 2011 Thanks for the replys guys, what a day.... Quote
chadz34 Posted October 3, 2011 Author Report Posted October 3, 2011 Beauty job, I guess the replacement ones are MUCH better and stronger....won't hurt to get the new bushings on there too! Quote
94 olds vert Posted October 3, 2011 Report Posted October 3, 2011 Just don't fix it like this!!! Quote
AMP Posted October 3, 2011 Report Posted October 3, 2011 my dad and mom had a 01 impala and the trailing arm broke on it and it look just like the pic. Quote
chadz34 Posted October 3, 2011 Author Report Posted October 3, 2011 Just don't fix it like this!!! WOW Quote
94 olds vert Posted October 3, 2011 Report Posted October 3, 2011 Yeah some good ole' Detroit engineering fixed that Cutlass right up. Quote
tornado_735 Posted October 3, 2011 Report Posted October 3, 2011 Wasn't even in bad shape....makes me wonder.... Yeah dude, the OEM ones are stamped out of that appears to be three layers of tin foil. You can damn near bend them over your knee. Quote
GaPrix Posted October 4, 2011 Report Posted October 4, 2011 Good thing you caught it. It's a fairly simple repair. If you can't get the bolt out of the body mount, your best bet is an air hammer or a cut-off wheel. I am pretty sure like, Advance or AZ have a decent replacement set for less than a hundred bucks. Someone here was talking about them not too long ago. That was me, a simple job turned into a nightmare. Bolt was seized into the sleeve, an air hammer would have been real nice. Cut-off wheel worked nicely though. Quote
GP1138 Posted October 4, 2011 Report Posted October 4, 2011 That was me, a simple job turned into a nightmare. Bolt was seized into the sleeve, an air hammer would have been real nice. Cut-off wheel worked nicely though. Same here. Cut-off wheel and a $20 angle grinder. Good luck! Quote
