Rebuilding valvetrain, possibly upgrading
The engine I am picking up for the GTP, I was told has quite a bit of valvetrain noise which I would like to eliminate... Would simply replacing the rockers (or upgrading to these http://zzperformance.com/grand_prix/products1.php?id=426&catid=104) quiet it down a bit? I am not sure what usually makes noise in the valve train... I do want to rebuild my heads with new valves, springs, lifters, and pushrods... Maybe even seeing if there are more upgrades I could do while I have the motor torn down... Suggestions? Mods are in my sig, I plan on adding headers and a ported supercharger
Lifters are 99% of the time the source of valvetrain noise on any hydraulic lifter engine. Either from a bad lifter(s) or an oil pressure problem.
Ooooooooooo those look nice! I don't think ill be putting a Cam in it... since it's my summer DD
its not really a noisy valvetrain, more like tired out. If it were me I'd replace the springs and perhaps upgrade the rockers.
not 150lb !! you only need those if you run a high lift cam, and then you need to upgrade to a double roller timing set.
I don't know much about the specs of springs... what can I upgrade to? I have a set of heads in my basement just waiting to be built up and installed
