AMP Posted September 28, 2011 Report Posted September 28, 2011 so i my car has been doing this for some time now anyway i can drive it to work and back with no problems then after that it runs really rough and then dies and wont restart. Quote
AMP Posted September 28, 2011 Author Report Posted September 28, 2011 oh and if some one would be so kind as to tell me how to add a video. Quote
94 olds vert Posted September 28, 2011 Report Posted September 28, 2011 I don't think you can upload vides to the forum without having them hosted on another site. Use photobucket or image shack and upload your video to that site and then you should be able to post it here. Quote
AMP Posted September 28, 2011 Author Report Posted September 28, 2011 ok thanks the video shows how it runs and what it does when i try and start it. Quote
AMP Posted September 28, 2011 Author Report Posted September 28, 2011 here is one video dont know if it viewable but here it is. Quote
94 olds vert Posted September 28, 2011 Report Posted September 28, 2011 It reminds me of this sound here. I also noticed that your starts were kinda hard. Is it always like that? I had a couple of bad injectors when I took that video. That's what it sounded like. Any check engine light? Quote
AMP Posted September 28, 2011 Author Report Posted September 28, 2011 you know i have not really noticed the starts being hard, light wise there is only change oil and i think the check engine light is on, the oil one is all ways one even after changing. Quote
94 olds vert Posted September 28, 2011 Report Posted September 28, 2011 The oil light is probably a sensor issue. Did you check for codes with the check engine light? Quote
AMP Posted September 28, 2011 Author Report Posted September 28, 2011 yeah i really don't know exactly how when it comes to that stuff. Quote
94 olds vert Posted September 29, 2011 Report Posted September 29, 2011 You have an OBDII car. So you can take it to Autozone or Advanced Auto parts and have them scan it for you. Then you should know what trouble codes you have. Quote
AMP Posted September 29, 2011 Author Report Posted September 29, 2011 oh that yeah i took it there a month and a half ago and all that came up was o2 censor and caddy convertor. Quote
AMP Posted September 29, 2011 Author Report Posted September 29, 2011 i swapped quail packs from my 98 cause it was good and it is the one on it currently and it does the same, ICM i don't know have not checked. Quote
AMP Posted September 29, 2011 Author Report Posted September 29, 2011 catalytic converter:lol:, my grandpa calls it a caddy converter. Quote
Crazy K Posted September 29, 2011 Report Posted September 29, 2011 do a fuel pressure test. Also, If you were to press the schrader valve (like tires have) on the fuel rail and any vapor comes out instead of liquid... that really narrows down your issue. Quote
AMP Posted October 3, 2011 Author Report Posted October 3, 2011 yeah ive done that good amount of gas came out, and it only does it when it is hot. Quote
