erok01 Posted October 20, 2003 Report Posted October 20, 2003 i'm installing my kyb's and lowering springs and had a question. because the spring is shorter, it isn't going to be oriented (sit in the perches) the same way as the stock spring. should i install the spring with the bottom perch oriented the same way as stock or is it more important to pay attention to the top perches orientation. i installed them last night and i get a horrible noise, like something is rubbing or bottoming out. i'm assuming it is the bottom perch rubbing against the inside of the fender. any tips on to position the spring or any input would be much appreciated. Quote
