1999 Buick Regal LS 3.8 Non Supercharged
Has Low Coolant light on. Levels are normal. My Uncle said that the coolant is the consistency of clay! He said not to worry about it, that it obviously has not been changed, and that it is a characteristic of Dex-Cool when its past due for changing. He said he'll flush it and that it'll cost $60 to replace the coolant sensor :roll:, well that damn light can stay on for $60, I'll just check the level myself weekly LOL
My main question is: Is it normal for Dex-cool to like turn to "clay" with the amount of miles and age of my car? I'm asking because my Uncle tends to be protective of me, and would say that even if the engine in my car was close to blowing up. LOL
Car does not ever overheat (I have only put about 50 miles on it in teh three months I've owned it.) Oil does not appear to have any coolant in it.
Thanks
BBCV
otherwise know as mississippi mud. Definitely would do a complete flush and refill with proper consistency.
oh, I'm going to do it. I was just wondering if my head gasket was blown or something. What causes it? miles?
Dex-Cool had some issues when it first came out. GM authored some service bulletins about flushing procedures and such. Some folks claim that it doesn't tolerate air in the system; but that doesn't make sense to me because they never bitch about the coolant in the overflow tank turning to sludge, and that's exposed to air 24/7.
"I" think the problem occurs when it's exposed to combustion gasses leaking into the cooling system...but I'm not spending millions of dollars for a chemical analysis of affected cooling systems.
Flush the contaminated stuff OUT, and I mean VERY THOROUGHLY. Refill with fresh coolant (Dex-Cool, some other brand of extended-life coolant, or plain-ol' green. Your choice.)
"I" would clean the existing low-coolant sensor and see what happens.
The two vehicles I own with Dex-Cool are in great shape, and years overdue for a flush 'n' fill.
My guess? Someone refilled the system with green coolant. IIRC regular coolant and Dexcool don't play nice.
Flush that bad boy and make sure you get ALL that crap out. Drain old stuff, fill with water, get to operating temp, dump water. I've heard people say to repeat that one or two times, YMMV. Then put whatever coolant in. That way you get as much Dexsludge out of the engine as possible.
Edited by white4d96
it may take 2 flushes. Mine was real bad like that.
you might consider replacing your LIM gaskets first if they are oem. and check your upper intake around the EGR while you are at it, make sure its not warping. Common problems.
Make sure you use distilled water with Dex-Cool.....Dex Cool does not like tap/well water
I just went through dexhell on a 3100 century. somewhere someone made it almost a 50/50 mix of green and dex. what a mess. waterpump went out about a month later and it got unplanned coolant flush again when that was replaced. might do good to run a radiator cleaner solvent and water around for a day or so to break down some of the crap buildup.
