Seem to be losing mpg, no clue why?
So my 'trigue seems to be getting lower mpg lately, and I can't figure out why. I have kept it regularly maintained and run some form of fuel system cleaner through it every other tank or so, and I don't have any other trouble with it. Any ideas on why? Thanks in advance
Nick
could be any number of things. dirty air filter, dirty throttle body, dirty MAF, o2 sensor, fuel filter, cheap gas, tires are low, heavy foot.......
I suppose I should have listed that stuff too. Within the past 200mi I have cleaned the air filter (K&N, so re-oil and everything), cleaned the TB, cleaned the MAF, aired up tires, etc. I do need to check the fuel filter though, I'll try that.
How many miles on the car? Last time mine began dropping suddenly, without apparent cause, the O2 sensor was dying...had about 50,000 miles on it. It wasn't setting a check engine light--yet.
Replaced the O2 sensor, and things went back to normal.
Where do you live? It's about that time of year that the winter blended fuel will be used in the north. (Which contains more ethanol)
Yeah could be the ethanol, I'm up in Wisconsin. I didn't even think of that. And as for the mileage, I'm at 134k but not throwing any codes or having any symptoms of trouble.
What was mpg before vs now? You can usually expect anywhere from 2-5mpg drop with winter gas. Anything more, you have got another issue.
I believe the gov passed a new 15% standard. We live in hellish times thanks to stupid people.
Yeah 2-5 sounds right, I got an avg of about 3mpg less one tank and 5 less for another. Two different gas stations too so I'll probably stick with the one that was only a 3mpg loss haha.
Choose one station, do several fill-ups and track it. If it seems to be getting worse with similar driving conditions (keep in mind colder weather will drop mpg's too), you need to look into some other issue.
I would also expect the gas companies have put out the "winter blend" for us up north. That will contribute to the loss in mpg, from the shit they put in it...
Damn gas companies and their "winter" gas. Drop the price if it's gonna drop mpg and be full of crap.
^ my bad, switched summer with winter blends. Still, it's not really technically "cheaper" when you lose mpg. You just end up having to buy more gas for the same distances.
No it's not, and when you figure how much mpgs you lose, it doesn't even go down enough to cover it. IIRC it's like 10 or 15 cents is all, but I could be wrong.
Yeah it does, I didn't mean that it isn't. I just meant that I don't believe the 15 cents per gallon is enough to offset the mpg lost. I could be wrong though.
No, you're right. Its just another way they price gouge you.
Well say you get 20 mpg and your'e driving 100mi, that's 5 gal. Lose 5mpg and you're up to a little under 7gal for that same 100mi. Even dropping the price .20 a gal wouldn't offset the difference.
Whats the difference between gasoline....and ''winter'' gas? I might have missed something?:shrug:
They put different additives in it. Not sure exactly what all goes in, but I do know that they put more ethanol in. Ethanol=lower gas mileage
I know that winter blend is more volatile so it will light off easier for a cold start. Blame the EPA...not oil producers. Wer'e not dying of asthma. Were dying from hi taxes/over regulation.
