Cougnut Posted September 25, 2011 Report Posted September 25, 2011 Hey guys, Recently I changed the EGR valve and Idle Air in the z34, and the engine light is still on. Went to my mechanic buddy's shop and he ran a scan for free, and it's still giving the codes for a bad EGR valve and Idle Air control. He told me to start saving for a new car, and it's most likely an electrical problem. I replaced the idle air/EGR because my car was dying out, and it was idling rough. We originally did a scan and that's what the codes read to replace the both. Ever since I replaced the EGR Valve and Idle air, I have not had the issues that I had before. Any ideas? Almost 100,000 miles on it. Quote
94 olds vert Posted September 25, 2011 Report Posted September 25, 2011 I would pull the ECM fuse for a couple of minutes and let the computer reset. Or disconnect the neg. Battery terminal. A CEL is no reason to buy a new car. Especially when you replaced the parts that needed to be when you scanned it. Quote
WhatTheFehl Posted September 25, 2011 Report Posted September 25, 2011 The EGR actually may not have failed in the first place... I've got a writeup on here about that somewhere. I'd link it but I'm on my.phone right now. Quote
Andrew Posted September 25, 2011 Report Posted September 25, 2011 did you clean out the tube that connects the egr to the exhaust? Quote
dodgethis Posted September 26, 2011 Report Posted September 26, 2011 I would run Seafoam through and go from there. Quote
