Lovemealumina Posted September 24, 2011 Report Posted September 24, 2011 I own a '93 lumina euro, but it seems theres a weaker signal causing static more often in it than ive experienced in other cars, does anyone else with a euro have this problem or is it just where i live? Quote
94 olds vert Posted September 24, 2011 Report Posted September 24, 2011 I put a noise filter in my GP. It seemed to have a lot of static when I fist turned the radio on. I still have some static, but it really helped to cut down on some of it. http://www.amazon.com/Peripheral-PAC-SNI135-Noise-Filter/dp/B002JIN50S Quote
Jprice90 Posted September 25, 2011 Report Posted September 25, 2011 have an aftermarket headunit? Quote
virtuetovice Posted September 25, 2011 Report Posted September 25, 2011 First off, try checking all your grounds and be sure they're snug and clean. Also, pull your radio out and check the antenna connector. They can wiggle loose. Quote
Mel87 Posted September 25, 2011 Report Posted September 25, 2011 Yeah grounding can cause a big issue. When we did the engine swap on our 87 we had disconnected the groundings, turns out we forgot to put on back on or grounded it wrong because same thing happened to us... lots of static. Quote
