Laveen Z34 Posted September 16, 2011 Report Posted September 16, 2011 Any ideas why my Z34 almost feels like it wanted to die when it is first started and engine still cold? Quote
Crazy K Posted September 16, 2011 Report Posted September 16, 2011 typical vacuum leak from an intake gasket needing replaced. when cold the leak is exaggerated. Quote
Galaxie500XL Posted September 16, 2011 Report Posted September 16, 2011 Very likely. A bad coolant temp sensor could do the same thing, particularly if it incorrectly reads the temp high. No fuel enrichment, because the ECM thinks the engine is warmer than it really is. typical vacuum leak from an intake gasket needing replaced. when cold the leak is exaggerated. Quote
Laveen Z34 Posted September 17, 2011 Author Report Posted September 17, 2011 LIMG replaced already about 2 months ago. What else d u think might be causing it? Quote
Laveen Z34 Posted September 17, 2011 Author Report Posted September 17, 2011 I'll check that and might as well replace it..... Quote
