virtuetovice Posted September 15, 2011 Report Share Posted September 15, 2011 First and foremost, I don't know if this has been done in the past so apologies if I'm hitting the replay button, so to speak. This is the thread to post useful tidbits of interchange info, or request it. Some of us have Hollander or other ways of finding this, but sometimes it's not 100% right. For example, I've found that door mirrors are directly compatible between Cutlass coupes and sedans. Now some of this may be redundant information for some of you but I know well that it's useful for plenty of others. I for one, did not know this until I simply tried. So, lets try to keep this page on topic. I'm sure it could become a plethora of useful info for visitors and members alike. Quote Link to comment Share on other sites More sharing options...
mra32 Posted September 15, 2011 Report Share Posted September 15, 2011 All windshields are the same IIRC Lumina coupe and Lumina sedan trunklids are NOT the same Outside door handles on Lumina sedans are also used on Corsicas Door closers are the same across all W-bodies but you have to match front or rear. I am unsure of if the front ones from a sedan will work on a coupe, though. All carpet in 1st gens is the same shape, you have to match the range of years though because the floor pan changed at some point Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted September 15, 2011 Report Share Posted September 15, 2011 (edited) Rims. Edited September 15, 2011 by 94 olds vert Quote Link to comment Share on other sites More sharing options...
Crazy K Posted September 15, 2011 Report Share Posted September 15, 2011 NO NO NO Gen 1: windshields are body type specific, coupes and verts are the same, sedans are sedan only. Quote Link to comment Share on other sites More sharing options...
urbex Posted September 15, 2011 Report Share Posted September 15, 2011 Oh, here's one that everyone missed! Gen 1.5 Lumina/Monte Carlos are the same thing! Quote Link to comment Share on other sites More sharing options...
virtuetovice Posted September 15, 2011 Author Report Share Posted September 15, 2011 Just found out that the power sedan mirror actually works correctly in my coupe, the connectors are even the same Note that the pigtail coming out of the sedan mirror is CONSIDERABLY longer than the coupe mirror. By considerably I mean an extra foot. It makes things a lot easier. Quote Link to comment Share on other sites More sharing options...
LuminaPower92 Posted September 16, 2011 Report Share Posted September 16, 2011 Oh, here's one that everyone missed! Gen 1.5 Lumina/Monte Carlos are the same thing! You mean Lumina Coupes. For you Nunzi. Quote Link to comment Share on other sites More sharing options...
urbex Posted September 16, 2011 Report Share Posted September 16, 2011 Luminacarlo! Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted September 16, 2011 Report Share Posted September 16, 2011 Lumina coupe door handles are Lumina only TGP and 91-93 GTP valances interchange B4U seat skins can be switched side to side (can use a passenger seat to rebuild a drivers) Grand Prix trunk lids do NOT interchange coupe to sedan Cutlass trunk lids do interchange coupe to convertible Cutlass coupe front fenders can be modified to fit convertible 94 Cutlass dash pieces surrounding the steering column are 94 only due to the round 94+ column CS sedan master window switch will work in a convertible but the trim bezel is the wrong shape CS coupe door speakers and associated door panels will bolt on in a convertible. Pass. side is prewired on all cars, drivers on some. Quote Link to comment Share on other sites More sharing options...
92GrandPrixSE Posted September 16, 2011 Report Share Posted September 16, 2011 95-99 Luminas and Monte Carlos are the same car. Quote Link to comment Share on other sites More sharing options...
89 international Posted November 7, 2011 Report Share Posted November 7, 2011 Will the front fenders from 92 and up CS coupes fit the earlier years? I need a fender and their hard to find up north. Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted November 7, 2011 Report Share Posted November 7, 2011 Will the front fenders from 92 and up CS coupes fit the earlier years? I need a fender and their hard to find up north. I did some searching and the 92-97 coupe fenders have a different side turn signal and the opening on the fender is different from the 88-91 style coupes. 90-91 Convertibles also have different fenders, but ones from a coupe can be modified to fit a convertible. So maybe they can be made to work as well??? Finding a 90-91 CS convertible is unlikely. Your best bet is going to be to find a 88-91 CS coupe fender. It will match perfectly. I'll be heading your way this weekend. If I have time I'll hit up a junkyard or two before then and if I find one I'll sell it to you. Quote Link to comment Share on other sites More sharing options...
Mater Posted November 7, 2011 Report Share Posted November 7, 2011 not sure if it is a direct swap but some one used 92?-97 coupe CS fenders on a 94 sedan if i ever get a coupe or convert i plan on doing the revers of this sedan noses on a coupe/convert Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted November 7, 2011 Report Share Posted November 7, 2011 Fenders are not a direct swap. Quote Link to comment Share on other sites More sharing options...
Necessity Posted December 9, 2011 Report Share Posted December 9, 2011 IIRC means...? Where did you get your windshield info? I have a 2000 Grand AM 4 door with a new windshield I want to put into my 2002 Grand AM GT 2 door. I just need to know if it will work. Thank you in advance for ANY light you can shed on the subject. Necessity Quote Link to comment Share on other sites More sharing options...
White93z34 Posted December 9, 2011 Report Share Posted December 9, 2011 If I recall Correctly Quote Link to comment Share on other sites More sharing options...
White92Cutlass Posted December 9, 2011 Report Share Posted December 9, 2011 (edited) I did some searching and the 92-97 coupe fenders have a different side turn signal and the opening on the fender is different from the 88-91 style coupes. 90-91 Convertibles also have different fenders, but ones from a coupe can be modified to fit a convertible. So maybe they can be made to work as well??? Finding a 90-91 CS convertible is unlikely. I've got a '91 Cutlass Convertible parts car in the For Sale section. $25.00 plus shipping for either fender. Edited January 12, 2012 by White92Cutlass Quote Link to comment Share on other sites More sharing options...
AL Posted December 9, 2011 Report Share Posted December 9, 2011 IIRC means...? Where did you get your windshield info? I have a 2000 Grand AM 4 door with a new windshield I want to put into my 2002 Grand AM GT 2 door. I just need to know if it will work. Thank you in advance for ANY light you can shed on the subject. Necessity They are the same... Alero and Grand Am rear windshields are the same also for future reference Quote Link to comment Share on other sites More sharing options...
Mark 97 Cutlass Coupe Posted December 13, 2011 Report Share Posted December 13, 2011 My Coupe has always had a difficult to work electric door lock switch on the drivers side. I have pulled 3 or 4 from junkyard cars, and they are no better. On a whim, I tried the passenger side switch (obviously gets much less use) and it works perfectly. No wiring changes, just snaps in. The only problem is that the switch works backwards, so the icon on the switch is wrong. No bfd. Makes life much easier when trying to let someone in the passenger side. Quote Link to comment Share on other sites More sharing options...
89 international Posted December 14, 2011 Report Share Posted December 14, 2011 So whats different about them? Measurements are the same in the front for both. Quote Link to comment Share on other sites More sharing options...
89 international Posted December 28, 2011 Report Share Posted December 28, 2011 I know the lights are different on them. The measurements are the same though. The front clip kind of swoops up to accomidate the shorter side turn signal. Also covers up the bottom front of the fender. As opposed to the earlier models that butted up to the bottom of the fender. Also another clue is, the 92-97 have unused holes on the bottom where the 88-91 would bolt right into. So??? I'd be tempted to try but dont want to buy a fender that wont work. Quote Link to comment Share on other sites More sharing options...
White92Cutlass Posted January 12, 2012 Report Share Posted January 12, 2012 Lumina coupe door handles are Lumina only TGP and 91-93 GTP valances interchange B4U seat skins can be switched side to side (can use a passenger seat to rebuild a drivers) Grand Prix trunk lids do NOT interchange coupe to sedan Cutlass trunk lids do interchange coupe to convertible Cutlass coupe front fenders can be modified to fit convertible 94 Cutlass dash pieces surrounding the steering column are 94 only due to the round 94+ column CS sedan master window switch will work in a convertible but the trim bezel is the wrong shape CS coupe door speakers and associated door panels will bolt on in a convertible. Pass. side is prewired on all cars, drivers on some. There are holes for speakers and bolt holes underneath convertible door panels? No cutting or drilling required? Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted January 12, 2012 Report Share Posted January 12, 2012 Red93 When I installed speakers in my 'vert the bolt holes and holes for the speaker were in place. Mine was even pre-wired on both doors. With some cutting the holes for the speakers are marked in the door panel. Then all you need is a speaker cover from a coupe. Quote Link to comment Share on other sites More sharing options...
White92Cutlass Posted January 13, 2012 Report Share Posted January 13, 2012 That is awesome! Any idea why coupes got door speakers and 90-94 verts didn't? Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted January 13, 2012 Report Share Posted January 13, 2012 That is awesome! Any idea why coupes got door speakers and 90-94 verts didn't? I'm not sure why GM didn't put in factory door speakers. Quote Link to comment Share on other sites More sharing options...
