thikstik Posted September 17, 2011 Report Posted September 17, 2011 OP mentioned that the car is at a friend's house. Whoops, ok. Lets ask that freind if fluid is showing up on pass side Quote
xennith Posted September 19, 2011 Report Posted September 19, 2011 I still have the 4T60-E out of the 93 parts car I had. It has 106K on it. the car had bad motor but the tranny was said to be good. Not sure of how to check it but it's sitting in my garage. Quote
virtuetovice Posted September 19, 2011 Report Posted September 19, 2011 (edited) Not sure of how to check This thread guided me through the "shopping process". There's a lot of useful info there. http://olskoolrodz.com/forum/showthread.php?t=31619 Edited September 19, 2011 by virtuetovice Copypasta wasn't cooked right Quote
thikstik Posted September 22, 2011 Report Posted September 22, 2011 Can I give you $100 to check the diff?!! Quote
thatcutteeboy Posted September 27, 2011 Author Report Posted September 27, 2011 This appears to be what's at fault on the Vert so I will try just replacing the case for now. Quote
Crazy K Posted September 27, 2011 Report Posted September 27, 2011 (edited) You'll need the differential too........ Something failed to break the case.... You will probably notice a missing spider gear. You could possibly get away with installing a new spider gear, but i would replace the differential to be safe. keep in mind that if you only put a case on without fixing the diff, the missing gear will cause the remaining gears to load unevenly and they will break soon, too. Edited September 27, 2011 by Crazy K Quote
thikstik Posted September 27, 2011 Report Posted September 27, 2011 X2 what Crazy said. So did you look at anything inside case yet? Car will not drive with a broken spider gear. A new diff is cheap, and its only a small task with hardest thing to do is to remove snap ring that retains diff. You can use a small pic and screwdriver. Quote
thatcutteeboy Posted September 28, 2011 Author Report Posted September 28, 2011 You'll need the differential too........ Something failed to break the case.... You will probably notice a missing spider gear. You could possibly get away with installing a new spider gear, but i would replace the differential to be safe. keep in mind that if you only put a case on without fixing the diff, the missing gear will cause the remaining gears to load unevenly and they will break soon, too. Hey I did have a balljoint come loose on that side earlier this year and the axle was pulled out. Could that have caused a crack that just got weaker. I still haven't physically looked at it myself but my friend said the crack is by where the speed sensor is bolted in. The car still moves under it's own power Quote
thatcutteeboy Posted September 28, 2011 Author Report Posted September 28, 2011 Check the #4 spark plug.WTF Quote
thikstik Posted September 29, 2011 Report Posted September 29, 2011 Just being sarcastic because Ive posted what to do over and over....you gotta pull that side case off, find out whats going on inside it and go from there. Only special tool needed is the big axle nut. good luck Quote
thatcutteeboy Posted November 4, 2011 Author Report Posted November 4, 2011 Finally got a chance to tear down the Vert to check the housing and sure enough one of the gears was what caused the housing to bust. Got everything out of the way and got stumped with this bracket that mounts to the housing itself. Took all the bolts that I could see out and something is still holding it. Heres a picture of the bracket that I am talking about. Can someone chime in here with any help Please? Quote
White93z34 Posted November 4, 2011 Report Posted November 4, 2011 it may be helpful to take the dogbone out and pull the engine forward some to relieve pressure on it? Quote
Bake82 Posted November 4, 2011 Report Posted November 4, 2011 Finally got a chance to tear down the Vert to check the housing and sure enough one of the gears was what caused the housing to bust. Got everything out of the way and got stumped with this bracket that mounts to the housing itself. Took all the bolts that I could see out and something is still holding it. Heres a picture of the bracket that I am talking about. Can someone chime in here with any help Please? That bracket bolts to the rear lower motor mount and to the block behind the alternator. Time to drop the altnernator out, along with lift the engine up a little bit to get it off the rear motor mount. I have fought with this bracket when doing my 5spd swap and it caused me alot of grief. I could not find a way to get it off w/o the altnernator being removed and having the engine lifted to take the pressuer off. and even then it was a paid to wiggle off the motor mount itself. You might have to take the bolts off the bottom of the mount and completely take the rubber mount out. Quote
thikstik Posted November 5, 2011 Report Posted November 5, 2011 youre almost there...the next difficulty will be removing the thin but large snapring that holds the diff housing. A small pick or screwdriver does work. Quote
