Idle issues.
92GrandPrixSE
92 GPSE, 3.1L with 172k. Just did a tuneup and cleaned the throttle body. I ran the car after the tuneup and it ran fine. Then I cleaned the tb to try and lower the idle, and now it wont idle at all, and sometimes it will rev up to 2-3k rpm. I'm at a loss.. Any ideas?
I've heard I should unhook the battery for a bit and make it do a relearn, do you concur?
Yep, try a relearn, their are directions somewhere on this site.
Might save you $20,. give it a try
I just picked up the tps, and a throttle body gasket set. Tempted to do the intake gaskets too. Replaced the IAC as well.
So, after replacing the throttle body gaskets, TPS and IAC, it still idles high. Checked for vac leaks and found nothing. :/
