joecutlass Posted September 5, 2011 Report Posted September 5, 2011 Im going to be replacing the passenger side axle on the 95gp, and it says i need an axke removal tool? What is this? I used a pry bar with the driver side... Quote
LuminaPower92 Posted September 5, 2011 Report Posted September 5, 2011 There was a tool kentmoore had where you would install it onto the hub and it would actually push the axle out of the hub and hold it there. As far as in the tranny, i dont recall any tool for that other then a prybar. Quote
19Cutlass94 Posted September 5, 2011 Report Posted September 5, 2011 Ive never used any "special tool" when doing this.. Quote
joecutlass Posted September 5, 2011 Author Report Posted September 5, 2011 I used an air hammer to get the axle out of the hub. I havent done an axle of the passenger side yet, thats why i was questioning it. Quote
LuminaPower92 Posted September 5, 2011 Report Posted September 5, 2011 I dont know about an air hammer on the axle though. Seems like overkill and might mess something up. Never needed something like that. I tap em with a dead blow and they usually are loose. Quote
Andrew Posted September 5, 2011 Report Posted September 5, 2011 takes a bit more than a tap! but ive always used a plain ole BFH. Quote
LuminaPower92 Posted September 5, 2011 Report Posted September 5, 2011 takes a bit more than a tap! but ive always used a plain ole BFH. Quote
BXX Posted September 5, 2011 Report Posted September 5, 2011 I use an air hammer with my blunt bit. Fits nicely on the nub so it wont screw up the end and damage any threads. Why use BFH when air hammer is more fun and less effort:lol: Quote
Cutlass350 Posted September 6, 2011 Report Posted September 6, 2011 (edited) Please do it the correct way. Otherwise, you risk ripping the seal, damaging the transmission shaft, or damaging the transmission case. For ~$40 you can do it the right way, and the easy way. That's assuming you already have a dent puller. Get either an KD 3164 KD Tools (KD 3164) Inner CV Joint Pullers for Slide Hammer or OTC 7507 CV Joint Fork Removing Adapter Or, if you don't have a dent puller: OTC7509 OTC Tools (OTC7509) CV Joint Inner Puller Complete Set (~$65) I've found that sometimes, you'll need to grind a little away in places to fit some tight spots (like on my Intrigue). BTW, according to GM, you're suppose to use a CV puller. Edited September 6, 2011 by Cutlass350 Quote
White93z34 Posted September 6, 2011 Report Posted September 6, 2011 I won't lie those above tools look like they would make for a EASY removal. something I would like to own at some point. However. I have yet to use anything other then a prybar, have yet to damage a transmission or axle seal. Quote
Drummer Posted September 6, 2011 Report Posted September 6, 2011 I've only used my hands to get them off in 2-5 jerks, but probably not the safest method. Forunately my transmissions have been good to me. Quote
BXX Posted September 6, 2011 Report Posted September 6, 2011 I work on cars for a living, have changed many many halfshafts, never damaged a seal ever using a prybar. Hell, i've worked with 2 lead techs, one with 29 yrs experience, and the current lead tech I work with with 41yrs experience (yes 41, he refuses to retire) and none of them have used anything but a prybar and an air hammer (yes, air hammer. Prybar wont work on certain Chrysler cars). Never seen anyone damage a seal yet. Quote
GP1138 Posted September 8, 2011 Report Posted September 8, 2011 I've used a long-blade flathead and a prybar as well. Quote
