Oilpatch197 Posted August 29, 2011 Report Posted August 29, 2011 (edited) These are the headlamps that the books tell me must be aimed with a headlamp aimer machine...problem is nobody has one locally(they just use the wall method) So I simply just parked my car perpendicular to the brick wall at Wal-Mart and drove back 30ft and go up to the wall again until I got the "hot spots" where they will not drift when I pull away from the wall. (using the bricked joints in the wall as a reference mark) Now if I get my low beam hot spots centered, then my high beams are wacked, so then someone told me I should adjust on the highbeams(since they just go straight down the road) so I tried that. Now, I am not happy with low beam performance, so I tweaked it somewhere in the middle, both the horizontal and vertical are off, I bumped a stupid doe and took out my grille. Any suggestions on how to adjust these? I also got a pair of Depos in storage(had to swap some hardware), they have the full bulb sheild on the low beam, so I could do the 9005 conversion mod., except the optics are not very good. Edited August 29, 2011 by Oilpatch197 Quote
Oilpatch197 Posted August 29, 2011 Author Report Posted August 29, 2011 (edited) Yes. Edited August 29, 2011 by Oilpatch197 Quote
