bronze93 Posted August 26, 2011 Report Posted August 26, 2011 Alright, when I bought the car SES light was on. No problem, checked it and it was the camshaft position sensor. I also noticed that when it was running quad driver 4 was listed as bad. Now I have changed the sensor and it won't start. I have fuel and spark. The fuel is probably 2 years old that is in the car. I'm going to put some high oct and fuel injector cleaner in in order to stabilize that. Now when I put the scanner and look at the information quad driver 1 and 4 are listed as bad and 3 is on and off bad. Is the ecu bad? Also, when you pull the cps does it matter if you twist it left and right to get it out or did I screw something up by doing that? Quote
