Steve Posted August 26, 2011 Report Posted August 26, 2011 (edited) Finally found a Cutty Vert in my local JY. Got the rear third light & moulding, both taillights broke & backup lightbar broke. Going back on Sat. morning it was103 & I rushed it & missed some stuff. Will get another pic of the whole vin# (glare & sweat rolling down my face was so bad could not see screen) & if someone needs anything let me know. Edited August 28, 2011 by Steve Quote
94 olds vert Posted August 26, 2011 Report Posted August 26, 2011 That thing is beat, but still has less rust than any 'vert in the junkyard I've seen. Is the front valve cover painted blue? Quote
Steve Posted August 26, 2011 Author Report Posted August 26, 2011 I don't think so but I'll check on Sat. I think it's just oil with dust. Quote
STGBROOK Posted August 26, 2011 Report Posted August 26, 2011 Steve if you look and see if the pin cups are decent , I need a set also the plastic piece under the pin cups that's held in with 1 screw on the right side. If the 'A' pillar w/strips are not tore up my friend needs them on a 94 he just bought. Thanks, Brook Quote
MemphisMan Posted August 26, 2011 Report Posted August 26, 2011 I don't need it, but you should grab that front STB. Those are always in demand so it wouldn't be hard to sell. Quote
1988PhantomFE3 Posted August 26, 2011 Report Posted August 26, 2011 It might be too much trouble for you, but I need a rear sway bar. My Son pulled an elderly lady out of the ditch during a snow storm and connected the tow strap to the sway bar (bent it)...how was I suppose to argue about that one! Thank you Ed Jimenez 360-674-7036 Quote
GOT2B GM Posted August 26, 2011 Report Posted August 26, 2011 By the VIN I'd say its a 93. If the drivers door master window / lock / mirror switch is in good shape I'll buy that from you. Quote
Steve Posted August 26, 2011 Author Report Posted August 26, 2011 Ok everybody I'll try & get everything if in good shape. Ed, your's is the only maybe it's going to be 104 on Sat & if it's too hard a job I don't know. Quote
jeremy Posted August 26, 2011 Report Posted August 26, 2011 I don't need it, but you should grab that front STB. Those are always in demand so it wouldn't be hard to sell. ....about 5 years ago..... Quote
STGBROOK Posted August 27, 2011 Report Posted August 27, 2011 Steve if you get this before you head out to the yard in the morning I just found out tonight that my header w/strip around the front is torn. Trying to find my leaks and the damn thing is split in the middle. I don't mean to be a pain in the azz but if that one ain't tore sure would appreciate if you would grab it..... Just tell me what you need for the stuff and I'll square up with you right away. Thanks, Brook Quote
Night Fury Posted August 27, 2011 Report Posted August 27, 2011 Grab that top! It's in great shape!!! Quote
Steve Posted August 27, 2011 Author Report Posted August 27, 2011 (edited) bump Edited August 27, 2011 by Steve Quote
Steve Posted August 27, 2011 Author Report Posted August 27, 2011 Brook I'll check out it out, but by the looks of this car it's been sitting out in the sun for a long time. Quote
Steve Posted August 27, 2011 Author Report Posted August 27, 2011 (edited) Ok here's what I got 2 pin cups good shape, 1 drivers side plastic moulding under pin cup, 1 master window switch 1 STB & Third brake light & panel The switch works fine, I tested it on my wrecked 94 vert, needs panel painted though. Ed, tried to get that sway bar out but had no way to compress rear spring to get the bolts out of the strut to remove, (sorry) All W/S were in bad shape or would rip when I tried to remove. Really this car was not in too bad of shape no rust anywhere. I don't know about the engine or trans, had 120000 on it. PM me about the parts. Edited August 30, 2011 by Steve Quote
94 olds vert Posted August 27, 2011 Report Posted August 27, 2011 About the window switch. The one on mine broke. I was able to take the cover off my old one and swap it on the new switch. Those pin cups aren't bad at all. Usually they are missing pieces around the rims. Quote
95cutlass Posted August 27, 2011 Report Posted August 27, 2011 How is the rear bumper reinforcement on the car, just out of curiosity? Quote
Steve Posted August 27, 2011 Author Report Posted August 27, 2011 Well I didn't look under the bumper but looks ok from the outside. Quote
95cutlass Posted August 27, 2011 Report Posted August 27, 2011 Well I didn't look under the bumper but looks ok from the outside. Thats okay no need for a special trip, i was just wondering because of mine being completly rusted out. Plus it would be ridiculous to ship. Quote
Steve Posted August 28, 2011 Author Report Posted August 28, 2011 My 94 was all rusted out & I didn't even know it till it got rear ended. I don't mind getting this stuff ( in fact I love rummaging around the JY) but it's an hour away in Bakersfield & at this time of year it's too hot! I found a 95 coup with the same color dash in perfect shape (Mine has a big crack in it) I tried for an hour to get it out & went through 3 bottles of water & gave up. Has any body removed a dash out of these, what a pain.I actually try & hit 3 yards but not today Quote
STGBROOK Posted August 29, 2011 Report Posted August 29, 2011 (edited) Steve let me know how to pay you for the pin cups and receiver. I have pay pal so if that will work we can do it that way. Too bad about the w/strips but I guess it's hard to find a set that's not dried out. thanks Brook Edited August 29, 2011 by STGBROOK Quote
Steve Posted September 6, 2011 Author Report Posted September 6, 2011 Went back to the yard & got a few more parts off a 95 CS coupe, I got the dash out, what a job took me about 2.5 hrs total to get it out also removed all those minibulbs from the instrument panel in case anybody needs them. . Quote
Aron Nance Posted September 9, 2011 Report Posted September 9, 2011 Any chance that convertible is still there, WITH the lower rear facia where the exhaust tips extrude???? Quote
Steve Posted September 12, 2011 Author Report Posted September 12, 2011 Should be but can't tell you for sure. The yard is an hour away from me & it would cost some $$ to ship. Quote
jiminyc Posted October 9, 2011 Report Posted October 9, 2011 OHHH! my! Please go and get the Chime module! I cant find one anywhere! Quote
