Well, I'm a newbe here and I need some advice from the know.
I recently purchased a new turn signal switch, cam and control arm. I plan on using the instructions on here to get into the steering column.
What I would like to do is spray a protective cover on the control arm for the turn signal/cruise control/wipers/brights.
I'm leery about using something as common as rust-oleum. I am considering getting something more substantial, such as paint protestant.
Why you might ask?
  • :thinking:
Well, I'm glad you did. To prevent the markings from rubbing off after everyday use like they have on every other button in my car.
Thanks
1995 Pontiac Grand Prix SE,
I would just install it as is. Your car is over 16 years old and it probably took a long time to wear the text/symbols off. Do you plan on having the car another 10 years or more?
If you end up doing it, i would reccomend plastic paint like Krylon Fusion Clear Coat, but it would probably look pretty out of place with a glossy finish.
coat all contacts with silicone dielectric grease....
but yes, the answer is a clear coat of some sort, maybe they make a matte finish in the fusion paint?
