Bake82 Posted August 22, 2011 Report Posted August 22, 2011 (edited) going to be doing 5spd swap on my 92 GTP. plan is to drop the cradle, while its apart wondering what i should replace. Plan right now is alternator, serp belt, cradle bushings, motor mount(thanks matt) thinking about oil pan gasket and maybe rear main but i don't know i fI want to mess with something if it's not leaking right now.... opinions? Edited August 22, 2011 by Bake82 Quote
Bake82 Posted August 22, 2011 Author Report Posted August 22, 2011 thanks matt! I may have access to a lift for this swap! maybe that will entice you more to come help:lol: going to order all parts and be ready to do it first week or two of september. Quote
GOT2B GM Posted August 22, 2011 Report Posted August 22, 2011 ok sounds good, Fil said he's game to come help too Quote
pwmin Posted August 22, 2011 Report Posted August 22, 2011 would be awesome if you could have the cradle blasted and pc'd while it's off. I wish I would have had the time every time I've done that before. As was said, definitely mounts, poly if you can/want, but solid for sure. Quote
Bake82 Posted August 25, 2011 Author Report Posted August 25, 2011 would be awesome if you could have the cradle blasted and pc'd while it's off. I wish I would have had the time every time I've done that before. As was said, definitely mounts, poly if you can/want, but solid for sure. Wish I had the time to do that. This is going to be a quick and dirt 5spd swap. Do the little extras but no major stuff where I will require it to be sent out to be done and have the extra down time. Anybody else think of anything? Quote
pwmin Posted September 1, 2011 Report Posted September 1, 2011 Wish I had the time to do that. This is going to be a quick and dirt 5spd swap. Do the little extras but no major stuff where I will require it to be sent out to be done and have the extra down time. Anybody else think of anything?too bad that's how it always goes Quote
White93z34 Posted September 6, 2011 Report Posted September 6, 2011 I'm a big fan of doing the oil pan gasket then, walk in the park to do it with everything apart, major bitch any other time. power steering hi pressure line is a good thing to swap as well. Quote
