Impulseblue06gto Posted August 15, 2011 Report Posted August 15, 2011 I have had an issue with my bcm/ programming of it primarily the prior owner of the car stated that the bcm went bad and he swapped another one into the car all electronics work except the airbags basically the red light displays hp tuners shows a question for bcm serial my qz is can the bcm be reflashed or is it a one time flash any help/suggestions are appreciated so I can have working airbags Quote
White93z34 Posted August 15, 2011 Report Posted August 15, 2011 I know the dealer can do it. a few things you might be able to try. with HPT (and perhaps someone well versed in it can clarify) check the VIN programmed into it. make sure the caps orientation is proper too. What I think you have is a VIN mismatch between the BCM and the PCM which pisses off the airbag system for some reason. I could probably bring over my Powertuner setup this weekend and see what it sees as well. What also might work is putting the original BCM back in since the airbag light does go out with that, but I think passkey gets irritated. you might be able to just disable that and run it that way. I don't know how to learn a key to those cars unfortunately. short answer is it is likely a vin number mismatch and if you could get a dealer tech with a TECHII to check it out it would probably be about a 10 minute ordeal to fix that, but then you are into an hour of dealer labour. Quote
AL Posted August 19, 2011 Report Posted August 19, 2011 Whats up Bill? I think D-I-Nunzio is on the right track with the VIN numbers Quote
