Transaxle output shaft seal replacement
I don't suppose the driver side transaxle output seal can be replaced without removing the driveshaft? Special tools needed to remove and replace the seal? There is a rumbling noise up front that sounds like a bad bearing, maybe a good time to replace that too while its all apart.
gotta pull the axle because the seal is round... dont need special tools, just some care needs to be taken not to damage the area that the seal seats into.
