95LQ1VERT Posted October 28, 2012 Report Posted October 28, 2012 Thanks for the help! But damn, closest thing to what I need, and its halfway broken. I will keep an eye out for one! Quote
Silentkillzr Posted October 28, 2012 Report Posted October 28, 2012 (edited) High Idle speeds can also mess up the trans. A car i sold to someone had a high idle because of a bad IAC on a TPI 350. Blew the trans up from it shifting into a gear at 1500rpm Edited October 29, 2012 by Silentkillzr Misspelled :D Quote
95LQ1VERT Posted October 28, 2012 Report Posted October 28, 2012 High Idle speeds can also mess up the trans. A car i sold to someone had a high idle because of a bad IAC on a TPI 350. Blew the trans up from it shitting into a gear at 1500rpm HAHA the truck was shitting into gear . No but seriously that was another reason why I was desperate to find a solution for this high idle. These trannys arent the strongest and I didnt want to replace it again. But I replaced the TPS and so far so good! Quote
RobertISaar Posted October 28, 2012 Report Posted October 28, 2012 the torque converter will be a deciding factor in those situations... a LQ1 converter stalls out to ~2100RPM, a TPI350/305 converter stalls out significantly lower. Quote
Silentkillzr Posted October 29, 2012 Report Posted October 29, 2012 HAHA the truck was shitting into gear . No but seriously that was another reason why I was desperate to find a solution for this high idle. These trannys arent the strongest and I didnt want to replace it again. But I replaced the TPS and so far so good! HAHA i totally meant shifting, wow lol. my bad. Quote
95LQ1VERT Posted October 30, 2012 Report Posted October 30, 2012 Lol Its all good, I understood what you meant! Quote
