On my 96 Grand Prix 3.1. The engine makes a chattering type sound from the serpentine belt area but when the a/c is turned on it stops and sounds fine. Any ideas?
The A/C compressor clutch is failing. Replace it and you'll be all set.
To replace just the clutch, you'll need a clutch puller and installer. Most parts stores rent them.
Man, you just can't get a break with yours cars. I agree with the AC clutch on the way out.
Is this cheaper/better than replacing the whole compressor?
You got that right! it wouldn't be so bad but I have friends that have 175,000+ miles on their cars, totally abuse them, do no maintenance, and have 1/10 the problems that I have?
Just replacing the clutch will be cheaper. A new AC compressor at the store could cost 200 dollars.
I haven't forgotten about the junkyard. Just had to work a full day today.
Hopefully I can find a shop willing to replace just the clutch. No hurry on the junk yard.
Yes. Love the car. I knew there'd be some bugs since the car only averaged 2k miles per year.
Doe's anyone know if the clutch can be changed with the compressor left on the car? I'm thinking if comp. has to be removed, might as well replace it with a new one. Input?
Good news for once. Took it to repair shop and they adjusted it. $40, noise is gone.
What did they adjust?? The ac clutch? or just your belt and/or tension and/or other pulleys. i also have belt chatter, what did they adjust?
I think they adjusted the a/c clutch. They said this is a common problem.
