crazyd Posted July 28, 2011 Report Posted July 28, 2011 My power steering pump makes a loud whiny sound that I haven't been able to get rid of. The more I turn the wheel and the higher the revs the louder and higher-pitched the whine is, so for example going fast around an onramp makes it scream like a whore. It's much louder when the A/C is on. Done the PS pump and the rack, but it still does it. WTF??? Quote
ManicMechanic Posted July 28, 2011 Report Posted July 28, 2011 Sure it isn't the A/C compressor? My '94 convertible sounded like it had a PS pump whine and it was the compressor. Quote
urbex Posted July 28, 2011 Report Posted July 28, 2011 Being that it's louder when the A/C is on would lead me to believe it might be the A/C compressor as well... Quote
94 olds vert Posted July 28, 2011 Report Posted July 28, 2011 I have the same problem. People told me hear that it was the compressor too. So a new compressor later it still whines. I've went through multiple new power steering pumps. Remans and junkyard pumps. My current one is out of a 94 GTP that had 45k and the power steering still whines. I've replaced the rack twice and put all new power steering lines in it. Rubber and hard lines. Was on a Ford forum they told me to flush it out and add some Lucas power steering fluid to it. Did that and it still whines. Then I went back to regular fluid. I've bled the system just like the manual says and it will still whines. I wonder how bad it will be this winter. Last winter the whine was really bad. It hasn't been really cold since I got this GTP pump. So far I really haven't found a fix for this. If I do I will let you know. In the mean time I just tell people it's supercharged. Works for me. Quote
ron350 Posted July 28, 2011 Report Posted July 28, 2011 I think a lot of the whine could be caused by the pumps pressure valve and spring set. My 96 Regal 3800 has had the PS whine since new. I tried replacing it with a rebuilt pump but that changed nothing. Pulled a pump off a 98 Lumina with a 3800 and this pump is almost silent. The only thing I notice besides the lack of whine is less power steering in a parking lot. Quote
Schurkey Posted July 28, 2011 Report Posted July 28, 2011 I'd be looking at the tensioner pulley/bearing. True enough, the PS pump/relief valve can whine, and it would change pitch with rpm or perhaps with steering load... ...but if it changes with A/C on or off, I'd be looking elsewhere. Realistically, it could be ANY of the accessories driven by that belt, but the tensioner would be my first inspection. How does the BELT look? Quote
crazyd Posted July 29, 2011 Author Report Posted July 29, 2011 Well I guess it's good to hear I'm not the only one. Belt is brand new. Compressor has also been replaced. The pump I have in there now came from a 95 M/C, but I might try one from a 98 next time I'm at the yard. Quote
