crazyd Posted July 28, 2011 Report Posted July 28, 2011 Every summer I try to fix my crazy sunroof, and every summer it still does the same thing. It almost always opens UP. But when I try to close it, it takes three or more button presses for it to close. And when I try to get it to slide back, it has to drop down and close up twice before it will slide back - if it does at all, which is rarely. I've replaced the switch and I've replaced its little controller board. What else is there?? Quote
Psych0matt Posted July 28, 2011 Report Posted July 28, 2011 Mine will always slide back and then slide forward, but a lot of the time wont go into vent mode, but when it does will close just fine I grabbed a spare switch last weekend at the junkyard, I didn't know anything about a controller board...? Quote
crazyd Posted July 28, 2011 Author Report Posted July 28, 2011 Sounds like you've got the same problem in reverse, doubt that switch will fix it... Quote
Psych0matt Posted July 28, 2011 Report Posted July 28, 2011 Sounds like you've got the same problem in reverse, doubt that switch will fix it... I kinda figured that, which is why I haven't put it in yet. Maybe just a wire rubbed through or something Quote
urbex Posted July 28, 2011 Report Posted July 28, 2011 Although that switch you have in the car doesn't look too great anyways with how loose it is. It probably wouldn't be that bad to have a new one anyways. Quote
crazyd Posted July 29, 2011 Author Report Posted July 29, 2011 Nobody else has had this problem? Quote
tornado_735 Posted July 29, 2011 Report Posted July 29, 2011 I did on my old '94 sedan. I'm willing to bet money it's the sunroof relays. Go to the junkyard, and find a couple of GP's with a sunroof. Yank the headliner, and harvest the wiring with the little relays. That wiring harness with the relays has connectors on both ends IIRC. Get a couple of them, and install them on yours. I say get a couple of different ones because you could pull one with the same failed relays. Quote
crazyd Posted July 30, 2011 Author Report Posted July 30, 2011 I did that already, but you're right I may have pulled one with the same failed relays. I'll see if I can find another one and try it again, maybe that's it. Quote
Psych0matt Posted July 30, 2011 Report Posted July 30, 2011 Good to know, and that would make perfect sense too Quote
crazyd Posted August 1, 2011 Author Report Posted August 1, 2011 Scoured the junkyard today and found a couple Eldos with a sunroof, an Aurora, and a '98 GP with HUD, but I doubt any of them would've had compatible wiring. Even found a '95 with a manual sunroof, which must've been aftermarket. I think I've still got my old harness somewhere, is it repairable? Quote
iroc2 Posted August 2, 2011 Report Posted August 2, 2011 if anything ive had issues with it going back so its open. mostly when its like 50 degrees (early spring, i wanted my windows down after a 0 degree winter lol) Quote
crazyd Posted August 8, 2012 Author Report Posted August 8, 2012 Bringing this one back, I've been checking the yards around here every time I go and have had a tough time finding the replacement relay box. I found a similar one in a Saturn, but it didn't work. If anyone comes across one let me know, it barely works now. Quote
GnatGoSplat Posted August 8, 2012 Report Posted August 8, 2012 If relays are the problem, you could always open the relays and fix them. Most people don't think to open them, but usually they come apart using a small flathead screwdriver and are really easy to clean any oxidation or burnt spots off the contacts. I always repair relays rather than replace them. Quote
crazyd Posted August 9, 2012 Author Report Posted August 9, 2012 It's actually a little box with a circuit board inside. I've inspected it, repaired some cracked solder joints and it was WORSE than when I started! Quote
GnatGoSplat Posted August 9, 2012 Report Posted August 9, 2012 You might also check the condition of the limit switches. I have a vague memory of my sunroof not working right due to crud in one of the limit switches. I cleaned it out with a pin and that fixed it. Quote
crazyd Posted August 9, 2012 Author Report Posted August 9, 2012 Where are they? I've never been able to find them. Quote
GnatGoSplat Posted August 10, 2012 Report Posted August 10, 2012 On the driver side of the opening about halfway should be a plastic assembly with 2 phillips screws. There is a little nub that sticks out on the side. There should be a little silver metal plunger thing sticking out of it about 2mm. Quote
crazyd Posted August 16, 2012 Author Report Posted August 16, 2012 I looked, but my '92 doesn't have anything like that. This is one of the ASC sunroofs, don't know if they were different. Quote
GnatGoSplat Posted August 16, 2012 Report Posted August 16, 2012 Ah, I see. Yeah, those ASC aftermarket sunroofs would likely be different. You could try emailing support at http://www.americansunroof.com/ and see if they have any tech docs they could send you. I've never had much luck getting any help from companies, but you never know. Quote
Oilpatch197 Posted August 17, 2012 Report Posted August 17, 2012 Aftermarket moonroof is inferior to factory by a long shot. I'd sooner do without, if it was me. I personally have a thing against sunroofs, in general they break, leak, and when they break its always in the open position, even though mine is still working('92 regal OEM sunroof) I expect it to "go" at anytime! Can't expect much more out of a twenty year old vehicle, EH. Quote
crazyd Posted August 17, 2012 Author Report Posted August 17, 2012 Now hold on a minute. I don't believe it's an "aftermarket" in the sense that it was installed after delivery. This retracts into the roof and has a sunshade built into the headliner, as well as an ASC manufacturer statement sticker on the door jamb. It was clearly engineered into the car, just installed at ASC St. Louis after being built. I assumed that was just how they were doing them back then. Quote
GnatGoSplat Posted August 17, 2012 Report Posted August 17, 2012 That's how the dealer-installed ones get installed, but factory units are completely different. The factory unit can't be installed aftermarket, because the hole is stamped into the roof sheetmetal itself and there is no border around the opening. I don't believe factory units use any parts from ASC either, I've never seen any evidence of ASC anything on any of the factory moonroof parts. Quote
skitchin Posted August 17, 2012 Report Posted August 17, 2012 My favorite word right now is wonky. Quote
crazyd Posted August 19, 2012 Author Report Posted August 19, 2012 (edited) That's how the dealer-installed ones get installed, but factory units are completely different. The factory unit can't be installed aftermarket, because the hole is stamped into the roof sheetmetal itself and there is no border around the opening. I don't believe factory units use any parts from ASC either, I've never seen any evidence of ASC anything on any of the factory moonroof parts. Yes, the hole is stamped into the sheetmetal and is fully recessed, and it has no border on the opening. There's no way this could be a dealer-installed unit. I have also taken the sunroof seal from a '94 GP in a junkyard with a factory sunroof to replace my old one, and it was exactly the same. Actually, I've got an idea - does anyone know the RPO code for the sunroof so I can check my build sheet? Edited August 19, 2012 by crazyd Quote
GnatGoSplat Posted August 19, 2012 Report Posted August 19, 2012 Yes, the hole is stamped into the sheetmetal and is fully recessed, and it has no border on the opening. There's no way this could be a dealer-installed unit. I have also taken the sunroof seal from a '94 GP in a junkyard with a factory sunroof to replace my old one, and it was exactly the same. Actually, I've got an idea - does anyone know the RPO code for the sunroof so I can check my build sheet? If it has the stamped hole, then I don't believe it could be aftermarket or dealer-installed, but if it's an ASC, that's an aftermarket company. Strange. Got pics? Quote
