joecutlass Posted July 20, 2011 Report Posted July 20, 2011 (edited) I had to replace the ecm in my gp yesterday. I got an ecm from a 94 corsica with a 3100. The car runs phenomenal now, but it won't shift out of third gear. should I replace the chip from the corsica with the chip from my original ecm? I didn't know if this would make a difference or not. Edited July 20, 2011 by joecutlass typos Quote
jimmyfloyd Posted July 20, 2011 Report Posted July 20, 2011 You probably should switch the chip. There is a chance the corsica had a different transmission, potentially a 3 speed. I know they switched right around that time from 3 to 4 speed transmissions Quote
94 olds vert Posted July 20, 2011 Report Posted July 20, 2011 Yeah 1994 was the first year they got the 4 speed. But I agree you should switch it anyway. Quote
RobertISaar Posted July 20, 2011 Report Posted July 20, 2011 94 3100 corsica is a flash PCM, no removable parts other than the knock filter. you could reflash the PCM with a W-body tune and then it should function 100%. Quote
joecutlass Posted July 21, 2011 Author Report Posted July 21, 2011 How do I reflash this pcm? I put the chip that was in my original pcm in this one and still no dice. Quote
BXX Posted July 21, 2011 Report Posted July 21, 2011 How do I reflash this pcm? I put the chip that was in my original pcm in this one and still no dice. Thats cause that chip you swapped is like Saar said, the knock filter. IIRC you will need a GM Tech 2 scantool, a laptop, and the proper .bin file to reflash the PCM. Quote
RobertISaar Posted July 21, 2011 Report Posted July 21, 2011 i can reflash it with just an ALDL cable. Quote
joecutlass Posted July 21, 2011 Author Report Posted July 21, 2011 So how do I get this to you and back quickly enough? Or this option be more. intelligent... Obd2 swap? And if this IS smarter, what would I need to do this? Quote
RobertISaar Posted July 22, 2011 Report Posted July 22, 2011 if you send it, or another like it(any of the 94-95 3100 from a L/N/W or from a 94-95 F-body 3.4) to me, just include a little cash for my time and return shipping costs and i can have it sent back the same day i receive it. Quote
