Hello guys, It has been forever since I have been on here. I have a couple of questions for my 96 9C3 Lumina. I have tried searching but still no luck on these specific questions.
I want to know if newer 2nd gen lateral links would work on my car?
Can I use the adjustable one for all four for more adjustment?
Who has the best write up for coil overs? I plan to AutoX more.
I have seen write ups for the front sway bar bushings from energy suspensions but has anyone done the rears?
TIA
TIA
1- Yes, you can use Gen 2 links. Being a tad bit longer, you will need to slot the struts so you can get camber set properly.
2- No, they are different lengths, the adjustable one is the longer rear one, and it can't be adjusted down enough to be the right length for up front.
3- Front or rears? Either way, talk to me. Im currently the only one who makes mounts. I can easily make mounts for the rear for your Gen 1.5
4- Simple, you just get the universal sway bar bushings in the right size for the rear. The bracket it comes with just needs the holes drilled out a bit wider for the strut bolts to go through. No big deal really. The inner bracket bushings, no poly bushing options, just new ones from a parts store will do.
Edited by BXX
Looking for CO's all the way around. I'm Wanting to run TGP wheels maybe and 245's all the way around. Any clearance issues?
And can I cut down and rethread the adjustable lateral links?
1- xlaces should clear fine.
2- no. I do however make rear links too:lol:
Pics of said everything? CO, Links?
Pricing?
Arms with poly bushings. They will come all 4 being adjustable. - $500 shipped
Arms with Teflon/Kevlar lined Heim joints - $800 shipped
My facebook link to the album with the mounts. Your rears will be different obviously than the Gen 1 rear mounts I make now. Fronts are $250/pair shipped, Rears are $240/pair shipped
Wow thats alot of money. But its really nice stuff. Just not looking to spend that
Then your kinda left with stock stuff.
Basically lowering springs (if you can find a set. Not sure who sells them anymore) and some poly front control arm bushings.
Its alot of money because its custom made, well built stuff
I realize this. But I am not looking to put that into the Lumina
