virtuetovice Posted July 7, 2011 Report Posted July 7, 2011 My friend's dad has an 89 GP, these are the symptoms: 1-2 shift is fine 2-3, it will drop into neutral[around 35 mph or so?] If he starts with the shifter at the 2 position, runs it to around 45 MPH and lets off the throttle for a second, it WILL shift into 3rd. It will not go into 4th under any circumstances. Does anyone POSSIBLY know what's wrong?? The fluid level is perfect, and the fluid itself is a nice clear red with no burnt odor. The only odd thing I noticed is a little bit of black residue on the dipstick. Car has 220xxx miles. Quote
virtuetovice Posted July 7, 2011 Author Report Posted July 7, 2011 Clogged/sticking valve maybe? Quote
AL Posted July 7, 2011 Report Posted July 7, 2011 At 220k, I would just put a low mile trans in it Quote
intern8tion9l Posted July 7, 2011 Report Posted July 7, 2011 drive to ny, buy tgp turbo setup for your car, tgp trans for said car. all problems solved! Quote
virtuetovice Posted July 8, 2011 Author Report Posted July 8, 2011 If anything, the TGP trans would go in my car. Quote
gp90se Posted July 8, 2011 Report Posted July 8, 2011 Run a bottle of trans cleaner thru as the instructions say, drop the pan and change the filter/fluid. if it solves the problem, do a transmission flush after to get all new fluid in. Quote
