ok ive got a 3100 lumina, heres the issue the car is hard to start, has a P0300 code "random/multiple misfire", smells like gas petty bad when its running, and i took my intake apart to clean the maf and found a beer can full of gasoline in the plastic bubble thing on the bottom of the hose in between the maf and the throttle body. when it was running i gave it a little gas and it bogged down. since then i havent ran it. i dont want to damage anything internal becausei dont have a cherry picker to rip the engine out.
im only 21 and im new to 3100 engines. im used to imports like most guys my age. i could rip apart a toyota engine and put it back together in an hour.
any ideas what is wrong with my lumina? id like to try to drive this thing sometime.
Fuel pressure regulator leaking? Pull the vacuum line from the regulator and se if it's wet with fuel.
