ras52 Posted June 27, 2011 Report Posted June 27, 2011 I'm sure that I'm not the first to run into this, but I have acquirred a 91 grand prix ste, and the glove box some how decided to lock itself. Of course there is no record of what the combo may be, nor is the "key" available. Any suggestions? Quote
White93z34 Posted June 27, 2011 Report Posted June 27, 2011 Those are easy to crack. Get a light and look to the sides of the numbers you should see some little teeth in there, turn the numbers till the teeth disapear repeat for the other digits and that should get you the code Quote
ras52 Posted June 27, 2011 Author Report Posted June 27, 2011 Those are easy to crack. Get a light and look to the sides of the numbers you should see some little teeth in there, turn the numbers till the teeth disapear repeat for the other digits and that should get you the code Thanx..........I'll give it a try..... Quote
